Results 1 to 10 of 10
Thread: Pentair Superflo VS - setting up to use heater and salt system
    Aug 2015
    Oakville, Ontario
    3
    I just replaced my old pump with a Pentair Superflo VS. I really like the pump. Is there a manual override that can stay in that mode until I turn it off so that I can run the heater and superchlorinate the pool? I'd like to run the pump at Program #3, which in my case is 2200 rpm.
    Thanks.
    38,268
    Re: Pentair Superflo VS - setting up to use heater and salt system
    Sorry you have not gotten a response.
    I do not know the answer to your question. I know you can manually turn on speed 3 but I do not know how long it will stay on. Have you checked the manual?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    My intelliflo is controlled by my Solartouch but I am able to select a different speed from the pump control panel when the pump is not under active control, which is solar on. I can't change speed settings or rpm from the pump but I can change it from speed 1 to speed 3 or 4 that I use for brushing the pool bottom and it stays there as long as the Solartouch is idle. As soon as the Solartouch engages again it changes the pump speed.
    What happens when you push speed 3? I would think it would override the program until the next start/stop time. Altough, if I change speed when my Solartouch has the pump it changes back within seconds.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,481
    Ralph,
    One option would be to use the optional wiring kit Pentair P/N 353129Z. This kit allows you to take 5 Vdc out of the Superflo through a relay or switch and then back into the Superflo on one of four inputs. Each input selects a different speed. These external inputs override the program and will run the pump at the selected speed until removed. Check out the specifics in your manual under "External Digital Control.
    Let me know if you need any additional info and I'll see what I can find.
    gonefishin's Avatar
    Joliet, Il.
    413
    Quote Originally Posted by Jimrahbe View Post
    Ralph,
    HI Jim,
    I've been trying to figure out if I can get away with buying the Superflow VS and still use a SolarTouch to change the speed of the Superflow VS pump while it's calling for solar heat. I've run across a post stated you use the wire kit you mentioned. Hook it to the SuperFlow VS and wire the yellow and red leads inside the solartouch to the "solar pump" terminals and use the internal relay (that I'm guessing normally signals the booster pump). This way no extra relay is needed.
    here's a comment from someone who bought the wiring kit
    To control the SuperFlo pump via the SolarTouch control panel, wire the Red and Yellow wires to the Solar Pump Relay inside the SolarTouch control panel. That's it, those are the only two wires you need for the SuperFlo pump and the SolarTouch control panel. Whenever the SolarTouch activates solar heating it will kick the SuperFlo pump into speed setting program #2, and whenever the SolarTouch turns off solar heating it will revert back to the normal timed program. No need to buy a second booster pump, or the more expensive variable speed pumps just to increase head flow volume to the solar panels when they are activated.
    What's your experience? Any thoughts on how to successfully hook these two together?
    Thanks
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    DFW, TX
    24,483
    Did you find that quote in a thread here? Did they say if it reverts back to speed 1when solar shuts off? There is another member trying get to figure it if they can control a Superflo VS with a Solartouch.
    Other thread is here, I'd like to add an efficient pump and a solar heater controller ???
    Jul 2014
    Bedford, TX
    7,481
    Gone,
    I do NOT use the relay cable kit, since I only have Intelliflo pumps. But, I have to "assume" that the SolarTouch has the ability to control a single speed pump, so I suspect this is done via a relay.
    Let me see of I can find any additional info..
    Jul 2014
    Bedford, TX
    7,481
    Gone,
    So, it appears to me that the Superflo has an "External Control" connector. Pentair makes cable P/N 353129Z, sold by Sunplay for about $50.. that plugs into the connector.
    The Superflo provides 5 volts to the connector which comes out the Red wire on the cable.
    You would then wire this five volt DC output to the input of the "Booster pump" relay inside the SolarTouch.
    Connect the output of the booster pump relay to one of the 3 speed inputs on the cable.. Green wire for Speed1, Yellow for Speed 2, Orange for Speed 3.
    When the SolarTouch turns on the Booster pump relay, the Superflo will ramp up to whatever Speed (color) where the five volts was connected.
    So, the Superflo would work off of it's internal time clock schedule until the SolarTouch turned on the solar system, which in turn would turn on the Booster Pump relay, which would ramp the Superflo up to the desired speed.
    When the booster pump relay is de-energized, the SuperFlo will return to its normal schedule.
    Looks like it should work to me... What am I missing?
    DFW, TX
    24,483
    Nice detective work, Jim! Seems like Pentair could use your help updating their manuals.
    gonefishin's Avatar
    Joliet, Il.
    413
    Thanks Jim!!!
    I appreciate the work you put in...it kept looking like it should work...but never seeing either unit before...I wasn't sure. This is great information you gave out...thanks again!
    Thanks pooldv for all the info and help!
    33' Aqua-Leader AGP
    Aqua-Rite t-15 SWG
