Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Jandy Zodiac Flow Sensor Bad?
    Angry Jandy Zodiac Flow Sensor Bad?
    I'm trouble shooting service numbers on my Aquapure and wanted to run the entire scenario by some folks before I spend money on replacement parts.
    • First error codes were the 125 & 194 - Clean Cell. I pulled cell and inspected it. No obvious build-up, but I cleaned it and got a few bubbles. Put it back together, still getting the 125 & 194 errors.
    • Took apart the big thing that holds the 4 filters, cleaned them and put it back together. Now getting 172 & 184 error.
    • Checked the front board per the troubleshooting guide. All numbers not exact, but only slightly off. Based on a couple of posts I read, this is acceptable.
    • Have an extra sensor from when I replaced the salt cell 2 years ago. Scrubbed it with a green scrubby and swapped it out. Still getting 172 & 184.
    • Pulled the old cell, cleaned the newer (2 year old) cell with the green scrubby again and put it back on. Now I'm getting a Lo error. Yesterday the salt levels were fine. Now I'm not getting any salt readings.
    My questions to the group:
    • Is it likely that both of these sensors are bad?
    • How long should a new sensor last? Two years seems like an awfully short time.
    • Should I do anymore testing or does it seem pretty clear that the problem is with the sensor?
    Lynn
    12000 Gallon Freeform Pool
    SWG
    Jandy AquaPure 1400
    Leslie's DPD Complete Chlorine Kit + FAS/DPD Chlorine Tester and Swirler from TFP.com
    Tree covered lot - cottonwoods and crepe myrtles. Great shade during the summer, miserable fall cleaning leaves from the pool.
    Re: Jandy Zodiac Flow Sensor Bad?
    How old are all of the components?
    Support the site
    I replaced the salt cell and sensor in July of 2013. All else is original with the pool, so 8 years old.
    SWG
    Jandy AquaPure 1400
    The trisensors are the known weak spot for the aquapure. I would try a new trisensor and cell cord.
    What is the actual salt level?
    Support the site
    The actual salt level, as of yesterday, was 3.something. Now it is ----. I don't have strips to test the accuracy of the SWG though.
    I saw someone mention the 'new sensors' in another thread. Is this considered a new one or should I be replacing it with another one with the little extra board?
    Amazon.com : Zodiac R0452500 16-Feet Port Sensor with O-Ring Replacement Kit for Select Zodiac Jandy PureLink AquaPure Water Purification System : Swimming Pool Chlorine Alternatives : Patio, Lawn Garden
    SWG
    Jandy AquaPure 1400
    Yes, that's the newest one. That's the one you want.
    I would also recommend getting a Taylor K-1766 salt test kit.
    TFTestkits.net
    Support the site
    I just saw a picture you posted in another thread. It looks like your adaptor board does not have the little black jumper installed. I think that you need it for your unit. Check this guide.
    http://cdn.lesliespool.com/wpdf/r053...stallation.pdf
    Support the site
    Thanks, James. I saw your posts in both threads. I will check the white wire and jumper. I'll also connect directly without the extension. I've been running with the board installed for 2 years without the jumper,. It would be amazing if a 5 piece of plastic solves my problem!
    Update ---
    I looked through The directions at the link you sent me. Thank you for that. I definitely did not receive those directions with my replacement sensor. I remember the instructions that I got being very confusing, and this document is very clear. I hope I still have that jumper, I usually keep extra parts but I don't know that I kept that one. If I didn't, should I be able to find a replacement jumper somewhere so I don't have to replace the entire sensor before I test this?
    Lynn
    SWG
    Jandy AquaPure 1400
    Not sure where to get an extra jumper. However, all it does is connect the two pins together. You could connect them some other way. For example, you could solder a wire across the pins.
    Support the site
    Roger that. Didn't have time to examine yesterday, but hope to get to it today.
    SWG
    Jandy AquaPure 1400
    p00lhack's Avatar
    Jun 2013
    Morganville, NJ
    4
    Did you get the information about the little white button on the daughter board? This is on the circuit board on the cabled connected to the multi-function sensor (temperature, salinity and flow)? When codes indicate "no flow" it is usually because it needs to be recalibrated. This fix is simple. With the pool pump and the AquaPure controller powered, hold in this little button for 7 or more seconds and release it. In about 1 minute or less, the codes for "no flow" should clear.
    If you have no idea what I am talking about, I can post a picture of this.
    28kgal, IG plaster redone summer 2014, 1.5HP Hayward Super Pump, Hayward DE6020 using Purifiber (NOT DE), Aquabot Solo, Jandy AquaPure 1400 a/k/a Nature2 FusionSoft SWG, RayPak RP9100 CuproNickel Heater
    I remember the calibration using the white button, but didn't remember how to do it. Thanks for that.
    Craziest thing though. I pulled the daughter board to get the jumper issue taken care of and decided to connect the sensor directly to the board so the pumps could run while I figured out how to connect the pins. I went to check on everything a little bit ago, and now I'm getting no errors.
    If it continues to work, I'll probably leave it alone for the time being.
    SWG
    Jandy AquaPure 1400
    Couldn't find a jumper at Radio Shack so pulled out the soldering iron and made do. It's not pretty, but it worked. For the first time ever, I get a solid green flow light on the board instead of a blinking one.
    While I was putting everything back together, I removed the extension cable, connected the mini board directly to the board, and calibrated. At first I was still getting errors, but now it's running error free.
    I've already ordered my replacement sensor. If my current sensor is still working when it arrives, I'll probably send it back.
    SWG
    Jandy AquaPure 1400
    Good job. Thanks for the update.
    Support the site
    Four days in, the old sensor is still working (no errors, at least), and the new sensor has been delivered to me. I'll probably give it another week and if the old one is still functioning properly, I'll send the replacement sensor back.
    Thanks again for all your help!
    SWG
    Jandy AquaPure 1400
    The old sensor started erroring again, so I ordered a new one. I've installed it, set it to program B and get the flow light. After about 10 minutes, I start getting error codes 125 and 194 again.
    Thoughts? I'm stumped!
    SWG
    Jandy AquaPure 1400
    Jun 2011
    Long Beach, CA
    2,780
    Which firmware version do you have?
    07270a04
    SWG
    Jandy AquaPure 1400
    125/194 indicate low current. That can be caused by a bad cell cord, a worn out cell, low salt level or a scaled cell. Since you have a fairly new cell and have already cleaned it, I would check or replace the cell cord and verify the actual salt level with a k-1766 test kit or a good conductivity meter.
    Support the site
  20. Back To Top    #20
    I'll try all that and report back. Appreciate the advice.
    SWG
    Jandy AquaPure 1400
