Results 1 to 11 of 11
Thread: Sand filter media too coarse
    Aug 2015
    Shoreline
    6
    Thumbs up Sand filter media too coarse
    I am a new member of TFP. I have recently slammed my pool to kill an algae problem, and have been waiting for the filter to clear the dead algae in the water about 1 1/2 weeks. The pool is nearly clear now. I have been adding sparkle up to the filter to enhance filtration of the very fine particulate left in the pool. I bought a new filter at the beginning of the process because the old one was 22 years old and the diverter valve was getting too worn out to rebuild again.
    I bought a Game, Sand Pro 75D, which comes with a 3/4 HP pump motor with a 12" filter. The pool store told me they were using glass media on all their pools and it was better than the good old #20 silica sand that had served me so well on my previous filter. So I paid 3X the price to get the "GOOD" stuff.
    I ran the set up for 3 days with no noticeable change in the cloudiness of the water, and the pressure side stayed at 8PSI the whole time. It was obvious to me that the particulate was going straight through the filter, not catching anything. I began to add sparkle up and very slowly I started seeing results. The pressure would build to no more than 18 PSI before I backwashed and started again. At that pressure the pump would not make enough flow to keep going so I would backwash.
    I don't remember having this issue with the 'OLD" sand. There were times that the pool would clear in 1 day when I opened it. I believe the sand is finer than the glass, and I am presently going to replace the glass with sand. Thoughts?
    16' round Doughboy AGP. Printed vinyl liner. 6,000 Gallons. Game Sand Master 75B filter
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,431
    Re: Sand filter media too coarse
    I have read many threads where they were sorry about changing to the glass. It just does not work as well.
    Kim
    Jan 2012
    'burbs of Augusta, Georgia
    7,288
    Sounds like a plan.
    Have you ever added a smidgeon of DE to your sand filter to increase its pickup of very small particles? It might help speed things up once you return to the sand.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    I haven't read too much good about sand replacements here. Be sure that what you're getting is pool sand. Good stuff. Study it before you pour it in. My findings on how not all sand is created equal
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Note also we have a couple of members in Texas and Louisiana who have had problems with Quikrete brand pool sand lately, possibly a labelling / packing mistake.
    Aug 2015
    Shoreline
    6
    The glass media I was given is Vitroclean. I did not do a side by side comparison vs the #20 silica sand that I had been using because I had already thrown it out. I do remember thinking as I was poring it in that it seemed coarser. Its very inconvenient and expensive to add sparkle up after every backwash. Is the dead algae particulate finer than every day stuff the filter deals with? This was the first time I had to kill an algae bloom so maybe this isn't normal filtering having to take place in this situation. I have not tried adding DE and have no experience with it. Is it cheaper?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    DE is cheap for people adding it to their sand filters. I bought 20 lbs for $20. I use about 1 cup of it every month or so. The 20 lb box will probably last me until 2025...
    Isolated Spa - 345 Gallons
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    It does take a while to filter out dead algae, however we have not had a lot of positive comments from folks who use glass filter media.
    Love TFP? Become a
    TFP Supporter!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    berger - I know what happened. You even said it yourself; "The pool store told me..."
    That's where the trouble began.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Aug 2015
    Shoreline
    6
    That's right. I have been taking advice from people who really don't know what they are talking about. They just kids, who are selling Aqua-quip's products. That's why I am here now. I get my test kit next week and I'll start doing it myself. I'm glad I found you guys. Thanks for the help!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    It is usually recommended to backwash when you reach 25% over your clean PSI on the pump gauge. At 8PSi, your backwash would be done around 10, if I am thinking correctly.
