No never found any kind of bond wire. I removed the rotted pieces of wood that previous owner had used to prop the pump/motor assembly up off
the ground and replaced with 2 bricks and a piece of tile.
Thought maybe the bond wire might be under that....nothing.
I don't think it's under the sand filter as there is a heavy plate it sits on.
Will my previous thought of attaching a lug to the ladder then running proper size copper wire in a groove on the decking then along the house
to the equipment help?
someone in this thread also mentioned tying that bond loop to the panel ground since they do that in Canada.
My initial gut thought is that might be a dangerous thing to do...having the ladder end up being connected to ground.
