Results 1 to 8 of 8
Thread: Houston Texas pool
    j_m_min's Avatar
    Feb 2015
    Houston, TX
    47
    Houston Texas pool
    it has been 100 or more an average. My daily bleach went from 1/2 bottle to 1 bottle every day to keep it up above 4 every day. I don't see any reason why the chlorine would dissolve as the temperature goes up. Unless the suns rays are just that more strong. Just curious if there is something else I should check. FC going from 6 to 2 every day.
    CYA 50
    CC is zero
    all readings seem good.
    25,000 IG plaster pool. DE Pentair 60 gallons. Hayward pump with Single speed AO Smith 2.4 hp motor. Pool installed probably 20 yrs ago. Taylor water tesing kit.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Houston Texas pool
    Mine has lost 4ppm on average for 6 years now with CYA at 60. It ain't just the suns rays, it's also the water temp itself. Throw in some bather load cause it's HOTT------and there you are!
    My pool is full sun ALL day.
    Jun 2014
    15,243
    Ditto here as well. We keep our eggs in the pool now for breakfast so they're hard-boiled the next morning. Just passed my OCLT to make sure it wasn't anything else. Sadly, it's the sun/heat. But hey, that's why we have a pool right!
    j_m_min's Avatar
    Feb 2015
    Houston, TX
    47
    I knew the sun could effect chlorine. I didn't know the heat could as well. This 1 bottle of 8.25 bleach a day is getting expensive. Still better than yellow algae I guess. Water temperature is super warm right now.
    Just wanted to make sure I wasn't overlooking anything.
    Thanks for the help as always
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Maybe you're a good candidate for a Salt Water Chlorine Generator?
    j_m_min's Avatar
    Feb 2015
    Houston, TX
    47
    I probably am. I just don't know if I want to spend $1500 to do it right now. Isn't that about what they cost to install? Is there any particular brand that is supposed to be the best?
    Aug 2013
    Oklahoma City, OK
    140
    Do some research but I was able to get my aquarite complete 40k system for $800 or so. I installed it myself which saved quite a bit of $$$. It was the best $$ I have spent on my pool hands down.
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    if you are comfortable with installing the system yourself, you can get the T-15 cell with the controller for about $900. plus the cost of salt, so count on $1k total. $1500 if you get an electrician,etc involved to install components
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
