Thread: My dry acid isn't dry at all...
    May 2014
    SW Washington
    61
    Let me start off by saying that I am a nurse. I took a full college course in chemistry and had the minimum passing grade. It is just not something that clicks for me. Now I will get to what may be an extremely dumb question.
    I have in my pool chemical stash a bottle of 7 lb Kemtek PH Minus. It is from appoximately 2 years ago and since purchasing it haven't used it again. It says on the front "Dry Acid". Since my pH is 7.8 I was planning on bringing it down (from my poolcalc numbers) When I opened the jug it was liquid which confused me because I expected a powder. I poured 28 oz into my measuring cup and figured I would do some more investigating.
    The more I research the more I think that container should have contained powder. Have I totally lost my mind? There's no way a bottle of powder could become a bottle of liquid, right? But why would they call it dry acid if it were a liquid? I have Googled like crazy and not found the answer I am looking for.
    14k Gallon 24' x 54" Signature RTL , 1 hp 2 speed Pentair Optiflow, 350lb Pentair SD80 sand filter, 2" leaky plumbing, a Zodiac G3, and my TF-100!
    Jul 2015
    West Tennessee
    6
    Re: My dry acid isn't dry at all...
    I had a container of dry acid once that sat in a very warm storage shed for over a year. When I went to dispose of it there was a small (about 1\2 inch) pool of liquid on top of it. It definitely was not water.
    The powder underneath had formed into a solid brick.
    Possibly the humidity from the air had an effect?
    I would not use that acid in your pool. Best to purchase some new.
    20,000 gal IGV 18x36x6 with 4' radius, Pentair Ultra Flow 1hp, Pentair CC75 cartridge filter, Stenner 45MP2. Built 2003.
    Chemistry teaches us that alcohol is a solution. That figures, as I have solved many of the world's problems while drinking!
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Dry acid should be just that, dry powder.
    I would not put that in the pool.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2014
    SW Washington
    61
    Quote Originally Posted by rocketo View Post
    Will definitely be getting some new acid and it makes me feel better that you had a simliar experience. I am sure sitting in a hot shed over two summers is not ideal conditions. I was just excited that I had it handy and didn't have to run to the store. I do regret putting it in now that I know something wasn't right. I woulder what my tests results will be later today when I am able to retest? Hmm...interesting.
    Jun 2015
    Phoenix, AZ
    73
    The dry acid should still be good. Some dry chemicals have such an affinity for water that they can suck it right out of the air.
    https://en.wikipedia.org/wiki/Desiccant
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Dry Acid is a milder acid than Muriatic Acid. Dry Acid is Sodium Bisulphate and Muriatic Acid is Hydrochloric Acid.
    Some people don't want to use Dry Acid in the pool because it can build up sulfates which may be damaging.
    Muriatic Acid is safe to use, with all the normal precautions listed on any chemical bottle.
