Thread: replace motor with smaller HP?
    Jul 2015
    El Cajon, CA
    3
    I have a failing Hayward Hydromax SPLE40016 pump motor (1.5HP). Some time ago, a pool "professional" suggested that I replace it with a .75HP pump. We have no water features or solar. What things do I need to figure out in order to replace this motor?
    All input greatly welcome.
    36k, IG, Fibreglass
    Hayward Microclear DE-4800
    Hayward Hydramax II 1.5hp single speed
    Taylor k-2006 with novice skilled owner
    22,551
    Re: replace motor with smaller HP?
    With no water features or solar, a 3/4hp full rated pump is probably plenty big enough.
    If you're just considering replacing the motor and keeping the wet end you'll also need to replace the impeller and shaft seal as well as the diffuser.
    Also being that you're in Cali, I don't think you can replace it with a single speed model. You need at least a 2-speed.
    Jul 2015
    El Cajon, CA
    3
    Understood and thanks. Also, love the comment about OCLT and SLAMming in your footer. One of the other areas I am just learning about...
    Quote Originally Posted by Bama Rambler View Post
    36k, IG, Fibreglass
    May 2009
    Youngsville NC
    395
    I believe the max HP for a single speed in California is 1 HP.
    OP - if you are looking to downsize your motor, then you also need to downsize the impeller in the wet end as well, or you will burnout the motor.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
