Consequences of high Ch, CYA, Borate?
tonto
Apr 27, 2014
10
California
PoolMath says I should replace 100% of my water -- CH (500), CYA (180), Borate (15). However, in So. Cal. we have drought conditions and I would feel somewhat guilty if I replaced the water in my 10,000 gallon pool. What are the consequences of not replacing the water? I keep my chlorine and PH well in balance and I clean the pool frequently, but these other measures have been high for years. I have noticed no physical or health problems. What do you recommend?
My first question would be what testing was used to determine your CYA number? Second, how are you chlorinating? Third, you say you are keeping your chlorine well in balance but by the FC/CYA chart you would need to be maintaining a minimum of 14 FC for a 180 CYA. Are you maintaining that?
As for replacing 100% of your water, you must have one of the targets set to 0. Assuming your reading of 180 CYA is correct then you would want to replace 67% of your water because CYA is the most troublesome level you posted.
Tonto,
I'd like to start off by welcoming you to TFP! I am very sorry for the "debate" that has occurred in your thread, from time to time we tend to get members on TFP that give info that while they believe it to be true......it simply isn't. To avoid extra confusion I've moved the sidetracked debate to this thread. If you wish to read up on the false advice given it can be found there.
As per your original question,
First off I would request that you provide us a full set of current test results and then we can help you with your CH levels. If I can also ask you, what test kit are you using? A level of 500ppm CH is surely manageable, but it's starting to push up towards the level where you need to watch other items such as pH to avoid scaling issues. As per your CYA level, a reading of 180ppm screams a drain/refill to me. At this high of a CYA level, you need to maintain a FC level of at least 14ppm to stay ahead of algae. At this level of chlorine it will be impossible to get an accurate pH level, as that test reads a false high at any level about 10ppm FC. Before I would give you solid advice I'd like to see a complete set of test results from your personal FAS/DPD test kit. Also, a current photo of your water will also give us a nice look at your water hinting to us any other current issues.
Please answer back with a current set of results and an answer to what test kit you are using. From there we'll guide you step by step to cleaning your water and setting up a plan for you to maintain your oasis.
Thank you all for your responses, although, I don't think I have had my question fully answered. Following is additional information.
I am using a Taylor K-2005 Complete(high) test kit. Following is a screen shot of the PoolMath results from my weekly testing today. The results are consistent with what I have been getting in the past. Weekly, the only maintenance I do on the pool is to add several trichlor tablets to my floater and a little acid as indicated by PoolMath, in addition to the usual sweeping and vacuuming. Also following is a photo of the pool. The water seems to be fresh and clear, with no signs of algae. Any further guidance would be appreciated.
Borate should not get too high and people intentionally add up to 50 ppm Borates. So I wouldn't worry about that. As for CYA, that's the biggest problem when it gets high -- meaning above 80 ppm or so. If one doesn't keep a high enough FC/CYA ratio and gets algae, then doing a SLAM requires an awful lot of chlorine when the CYA is higher.
Yes, borate is fine, mine is 50ppm on purpose. Your CYA is super high, I did not notice that first time. For that more than 50% water drain is needed. I like Chemgeek's target of 80.
