Thread: Liner Advice please
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Liner Advice please
    I had our inground installed a little less than a year ago. This summer, it has started forming what I think would be divets on the floor. This spots vary in size from the size of a quarter to one that is the size of my foot. I called the builder as it is under warranty, and they replied that I could really do anything till the time comes when the liner needs to be replaced.They also stated that my liner would be fine. So my question is, is this normal, and are they correct? Since it's under warranty, would you demand they come out and fix it, or just have them put in writing that they will cover all replacement costs if the divets cause the liner to fail. I think they just didn't tamp the ground well enough before putting the liner in. Thanks for any help or suggestions.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Liner Advice please
    I don't know if they would be responsible if the liner failed due to divots under the liner. Those divots could be due to poor ground prep or they could be from ground water eroding the floor under the pool, or moles or other burrowing animals tunneling under the pool.
    Liners are made to stretch a good deal so the divots probably will not hurt the liner. You may want to investigate and see if there is anything causing similar divots in the yard.
    Love TFP? Become a
    TFP Supporter!
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    zea3 hit it right on all points. I would investigate for burrowing animals and if that's not the case, see where your pool is located as to whether you could be in a spot where the water table could be high underneath. My first guess if the divots don't get real big or you don't have numerous others show (like a mini sink hole ) is that they probably didn't do enough prep work on the soil before installing.
    As zea3 pointed out the liner should stretch enough to compensate for them. BUT they can be real annoying and I personally would think they should address it if it is poor prep.
    The thing I would worry about if it is water "gathering" underneath, would be if it could cause the bottom of the liner to "float" as it can in an inground liner. But from what you are describing I would tend to think that is not your problem.
    Hope that helps, let us know what you find out, as I'm am curious
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    lefty51's Avatar
    May 2015
    451
    Also might add, you say one is the size of your foot. When I install our AG pool at our old house, I didn't do good prep work and the divots the size of my foot were just that ! My foot prints left behind
