Results 1 to 14 of 14
Thread: New pool need help before i fill it up for the first time
    Aug 2015
    Okeechobee Florida
    5
    Ok i am new to pool ownership and my wife hired someone to put it up and i don't think he knows what hes doing he put some water in the liner and then proceeded to say the well water was bad...this is what he meant and thats before any chemicals were added any suggestions? Is there a way to clean that water without dumping it or should i dump it and get water delivered and does anyone know a good water delivery place in south florida that they would recommend
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: New pool need help before i fill it up for the first time
    It is hard to tell what we are looking at in that photo
    Aug 2015
    Okeechobee Florida
    5
    its the water straight from my well before any chemicals were added
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    That's most likely Iron. Look at pictures in these threads and see if you don't get inspired. If you do, do what they did.
    A Tale of Two Filters... and Ugly, Rusty Water.
    Just got Taylor-2006 Test Kit. Want to verify what I should add.
    Results of first TF-100 test ran on fill water - Page 2
    Let the pH and FC stay on the high end and grab as much precipitate as you can, and then add a metal sequestrant to deal with the leftovers.[/QUOTE]
    Sep 2013
    Connecticut
    728
    He said that's before adding chemicals, though. People report an effect like that pretty often AFTER adding the first dose of chlorine. Straight out of the tap looking like that is alarming, and makes one wonder how high the iron concentration may be. Original poster, does your water look like that when you fill a pot in the kitchen, when someone takes a bath, when you look in the toilet tank, etc.?
    If not, I wonder if the large volume drawn for filling the pool stirred up dirt in the well that you don't usually get in normal operation.
    It might be worth getting a jar of that pool water, let it sit for a day, and see if it settles.
    Also, please get some bleach in there ASAP, so algae doesn't start growing while you contemplate the esthetics of the water. Adding bleach might also be instructive about chemistry - if it gets even darker, that would certainly suggest iron.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Quote Originally Posted by singingpond View Post
    +1 on all of the above suggestions.
    So, did you ask him why he continued to fill the pool if he knew the water was "bad"?
    Dom
    Where's my manners........
    Welcome to the forum!
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2015
    Fort Pierce, FL
    129
    You're not far from me, Okeechobee. My well water bypasses my water softener but it didn't come out near looking like that. Was a bit green and cloudy but cleared up nicely with chlorine and filtration. Add some bleach and run your pump/filter for a day or two and see if that clears it up, this will be interesting to see. Your yard also looks pretty flat so I'm afraid if you drain it the water will just sit there and flood your yard.
    Intex 16x48" Ultra Frame AG Swimming Pool 5K gal
    intex 2650 sand filter
    Aug 2015
    Okeechobee Florida
    5
    Ok so the pool installer came ck today and is currently treating the pool so i will update then
    Aug 2015
    Okeechobee Florida
    5
    The ground is sloped down towards a field with drainage that picture is with the camera pointed toward the water which was only partly filled at the time
    Jun 2015
    Fort Pierce, FL
    129
    gotcha. Good luck!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Weasleyferrier1, you have no idea how we tend to cringe when we read statements like "Ok so the pool installer came ck today and is currently treating the pool so i will update then"
    If possible find out exactly what they add to the pool, as it takes the guessing game out of trying to undo their mess later
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Quote Originally Posted by Isaac-1 View Post
    +1
    Get a list of what was added and how much of each.
    Dom
    Dom - TFP Guide
    I'm on a well with high iron and every time I have filled (had intex before my permanent AGP) it is orangey-greenish looking before putting any chlorine in. Once water got to the skimmer and we could filter we then put in the chlorine (lots)and filtered non stop and it was gone very quickly. Like -2days tops. My water is beautiful now!
    Aug 2015
    Okeechobee Florida
    5
    So my pool is full of sediment from my well my pb put in chlorine and some metal out 20oz now ive let it settle and all the stuff is on the bottom im going to vacuum it out woth a skimmer attachment tomorrow morning if its not raining which its been pretty constant for the past week here any suggestions on how to vacuum it out without completely blowing out my pump ? If imfo is needed in the pump its a sand pump it a currently storming so i have to wait to get all info
