Results 1 to 20 of 20
Thread: Rain = Bad water. Please help
    May 2015
    Moline, IL
    31
    My pool water was good and then we got nailed with a ton of rain and now my pool looks like i havent used it in years.
    Free CL of 3.46
    TL CL of 4.79
    PH of 7.6
    ALK of 226
    Cal Hard. 324
    I am assuming that my Alkalinity is high and I need to lower it and is why it's the way the water is? What do I use to fix this? I have an inground pool with about 35,000 gal of water
    Aug 2014
    Shallotte, NC
    693
    Re: Rain = Bad water. Please help
    I'm going to make some assumptions.....
    First and foremost, you need your OWN test kit. We do not trust the accuracy of pool store testing. Your TA is off the charts and so is your CH, because you are using pucks and powdered chlorine/shock.
    Get a good test kit like the Taylor K-2006C and post all of your numbers. Until we can tell factually where you ARE, it is impossible to tell you what direction to take...
    May 2015
    Moline, IL
    31
    That is using my own test kit. Am I not supposed to use pucks and powdered shock? I use liquid chlorine so should I use liquid shock as well?
    38,463
    Must be a colorQ. We don't recommend them either.
    You did not post a CYA number which determines the required FC level.
    May 2015
    Moline, IL
    31
    Ya its the ColorQ PRO 11. I take it the ColorQ PRO 11 is junk?
    JoyfulNoise's Avatar
    May 2015
    13,247
    Quote Originally Posted by brandon1 View Post
    Hi brandon1
    When you report water test results, use the following format -
    FC
    CC
    TA
    pH
    CH
    CYA
    We don't care about total chlorine and prefer if you use your DPD-FAS reagents to measure FC and CC separately. If you format it like that (and mention that you used your K-2006 or TF-100 Kit), then the experts around here will not question your test results. Other formats look too much like pool store test printouts so it raises eyebrows when they're presented that way. And you only need to report chlorine values to the nearest 0.2 or 0.5ppm. Using more significant digits than that is also a dead give away of pool store testing.
    In all honesty, the rain doesn't really affect chemistry UNLESS you stop test and adjusting water during the rains. A lot of people (including me) slack when the weather is not sunny and that is what typically causes water to go south.
    Your CCs are high at 1ppm and you report cloudy water. Therefore you need to SLAM your pool.
    Matt
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    They aren't junk, but are not nearly as reliable and cost effective as the TF-100, which is the best kit you can buy for home testing of your pool. The Taylor K-2006 is passable as well but you'll need to order reagents sooner with that kit. The TF-100 from tftestkits.net is worth the investment as a proper home test kit is the most important tool for maintaining your pool and dealing with problems. You'll have much less problems with a good test kit and TFP methods.
    You need to be able to accurately measure CYA, FC and CC in order to deal with cloudy water and to properly SLAM the pool. Spend a little time in Pool School, starting with ABCs of Pool Water Chemistry and review the links in my signature as well.
    Isolated Spa - 345 Gallons
    Aug 2014
    Shallotte, NC
    693
    No, we do not recommend powdered chlorine... and you shouldn't need shock, at all. (At least, "shock" in the PS sense.) You likely don't have enough chlorine, but we can't tell because you didn't post your CYA level. If you have been using powders, it is likely your CYA is off the charts, too..... and that means you are WAY low on chlorine. I'm guessing that you have to fight your pH due to the high TA. The CH could be an issue, depending on your pool type...
    Powders and pills drive your CH and CYA through the roof. Elevated CH can cause scaling and elevated CYA virtually assures that you won't have enough "active" chlorine and the inevitable result is cloudy or green water... (all it takes is heavy rain to start the ball rolling)
    Some test kits just aren't accurate and that is documented on this forum. Absolutely none of the test kits can analyze chlorine accurately to 2 decimal places......
    May 2015
    Moline, IL
    31
    What about using WaterLink Spin Lab as a pool tester?
    May 2015
    13,247
    Same problems as a ColorQ. None of those electronic test kits are recommended and none of them will work when you need to SLAM your pool water.
    Matt
    Feb 2014
    Central Minnesota
    5,080
    If the test kit is not on this list, it's not recommended here and experts won't give much credence to your results. Pool School - Test Kits Compared
    May 2015
    Moline, IL
    31
    I was looking for something digital as I am not very good with matching colors on the testers :/
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    That product carry's a hefty price with a street cost around $1000. Save your money and get one of the recommended kits along with a SpeedStir
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Feb 2014
    Central Minnesota
    5,080
    The only test that are color MATCH in the recommended kits are the total chlorine and pH tests. The rest of the test are color CHANGE tests. FC and CC are from pink/red to clear. TA from green to red. Etc. The important tests for dealing with pool problems are all color change. The daily check tests of TC and pH are the only color match tests.
    May 2015
    13,247
    The tests, for the most part, use titration (drop counting) and color transitions (pink to clear, green to red, purple to blue, etc) that are fairly easy to read. I have mild color blindness but I am still able to see the tests clearly if I am in good lighting. The only color matching test is pH and, if that is really a problem, you can often find cheap electronic pH testers for ~$50.
    Matt
    38,463
    You don't have to match colors for the recommended test kits except for pH. You count the drops until you see a color change. For the CYA, you liquid until a dot disappears. There are videos you can watch to see the tests.
    May 2015
    Moline, IL
    31
    Ordered a TAYLOR K-2006C. I will post results once I get the kit. Thanks for all your help We need more good ppl like you in this world
    May 2015
    13,247
    Look up SpeedStir (and SampleSizer, all by Taylor Technologies). It makes doing the tests a lot easier. Totally not necessary or required to do any of the tests, but if you like gizmos, they're fun to have.
    Matt
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I have to admit that I thought the SpeedStir was a bit gimmicky but once I started using it, I found it nearly as important as the TF-100 test kit.
    I even made room in my case to store it nicely and polish it nightly.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
  20. Back To Top    #20
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Agent99 View Post
    I considered getting my SpeedStir bronzed but I didn't want to inadvertently add copper to my samples. LOVE IT!
