Results 1 to 20 of 20
Thread: ITCHY BURNING SKIN IN POOL
    We have a commercial indoor swimming pool with a autopilot salt generator. First we want to thank everyone for their help on our last post. We have solved the problem with coughing due to an oversizing of the equipment. We are now operating 2 salt cells at 50% instead of 4 at 100%. The only problem we still have is that our female teachers are haveing itchy burning skin in the pool. None of the male instructors are affected. Does anyone know why this would happen. Free chlorine is kept at a 1.5 - 2.0. PH at 7.6 water temp is kept at 90 degrees. Again only the female instructors are having this problem. We have 7 females total and 6 of them have the problem
    30,403
    Re: ITCHY BURNING SKIN IN POOL
    Posting test results for Combined Chloramines might give us a clue. Are you running CYA in the pool?
    Combined Chlorine is 0.1 - 0.2. CYA is 15 and dropping since we are an indoor pool. We were using tabs until we got our salt system running.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    interesting it only bothers the ladies and not the men ...
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Quote Originally Posted by TizMe
    Very. Are they showering before they get in? I wonder if they're all using a product beforehand that is reacting to the pool water?
    The weird part is we have 2 locations. The only one that affects them like this is that location. The other is an indoor pool as well but using tabs, not a salt system. We aren't sure its the salt that is causing it because before we got salt at that location, they still had the same problem. Any ideas on what to try or what to check for? Would phosphates have anything to do with it? Or should we drain the pool and start over, willing to try anything. Oh ya it only affects the teachers, the kids aren't bothered by it.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by lvwaterboy
    Power of suggestion?
    It would help to see a full set of water test results.
    Jul 2007
    Brisbane, Australia
    874
    Glad that i was correct on the previous issue
    Do both pools have same water chemistry?
    Could it be that females are more sensitive to the level of chlorine than men?
    I know when we go to pool with my partner she always feels it, and i never do
    11,969
    I was totally serious about the power of suggestion thing... You said the "problem" existed prior to the salt system. How many complained at the time? How many complained after the switch to SWG? My first thought was when they learned a "new" system/product was being used, one perhaps complained of a itchy/burning sensation and then the others "thought" they felt it too. The fact that the kids aren't complaining.....Is there visible evidence, does anyone have a rash?
    I've swam/swum ( ) in all types of sanitized (or not) water, and never noticed a difference, if anything I thought the saltwater pool had the best feel to the skin....very soothing.
    They are showing rash marks on their arms and legs. They all have went to the doctor and were prescribed cortozone creame and that seems to be the only cream that helps. The last doctor told one of the teachers that there is a bacteria in the water. Crazy stuff. Running facilities for 12 years and have never expericenced anything like it. What to do? Is there anywhere we can send our water to get a full testing done on it?
    11,969
    What are you testing with now? If you can't run a full set, a nearby pool store could do it. You need to do it within a relatively short time frame or the accuracy could be in question. If the FC is at the proper level I can't believe bacteria could regularly survive... that seems odd.
    So back to testing, what kind of test kit do you have now?
    Using a Taylor test kit. We checked all the normal stuff ph, alkalinity, FC, TC, CYA. Didn't know if there is something else I should be looking for
    30,403
    Ditto!
    Would you mind sharing those numbers?
    What is the water temp? Is this a therapy pool? Do you have an ORP controller on it? If so, what is the ORP?
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Not sure on the last two q's, but I believe he mentioned the temp is 90.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Summarizing the numbers from the previous posts for him (and us):
    FC : 1.5 - 2.0
    CC : 0.1 - 0.2
    pH : 7.6
    CYA - 15 and falling
    temp : 90 degrees
    indoor pool.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Is there any way that there could be something like fiberglass in the filter which might be breaking loose and getting in the water?
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by Ohm_Boy
    I would think fiberglas would affect everyone, not just the womenfolk.
    Intex 8110 SWCG
    "Fear the Schnauz!"
  20. Back To Top    #20
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I would expect a chemical problem to affect both sexes as well, but either way, a lot of guys have less sensitive skin than many gals. I am just brainstorming, and when there didn't seem to be a water-chemical cause, I started looking at the environment.
