Thread: Any do and don't for distance of equipment from pool/spa?
    May 2015
    Fullerton, CA
    635
    Looking for length of the plumbing runs to not loose heat and efficiency.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Any do and don't for distance of equipment from pool/spa?
    They can be longer than you think. Keep them to less than 100 feet and you will be fine. Shorter is better, elevation changes matter more. 20to 40 feet is common.
