Results 1 to 8 of 8
Thread: Electrical question for a layman like me.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Quick question...I was reviewing the electrical bill and was surprised with the new pool we seem to be using about 21kWh/day more. Being in Central Florida we run the A/C 24x7 in the summer time so I was expecting an increase, but not two fold. I have the pump on high for one hour a day and on low the second hour. I only circulate water two hours a day. I also have a Clear03 which is 220v (not sure of the wattage). The heater is gas...and frankly hasn't been used in a few months anyways. The control panel is a Zodiac/Jandy iAqualink which obviously is on 24x7.
    The only other electrical item I have is three Glo-Brite LED lights (which are rated at 23W). The two pools lights are on one transformer and the spa light is on a separate transformer. These lights are on from 6p - 10p (four hours). Am I correct in assuming that the transformers will only use 69W since the lights are rated at that...or is is possible the transformer is drawing more power than that? Not to mention they are 110v....just trying to get an idea if shutting off the lights is going to make much of a difference (I assume it won't...but you guys are the pros):
    Here are the specifics of the readings (the kWh/day is adjusted based on the number of days between readings):
    Date kWh/day kWh/day over previous year
    7/6/15 54.1875 19.80818966
    6/4/15 49.76666667 17.56666667
    5/5/15 37.89655172 18.61530172
    4/6/15 31.15625 17.41431452
    3/5/15 46.76666667 31.96021505
    2/3/15 31.86206897 12.63626251
    1/5/15 38.09375 21.23168103
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    Jun 2012
    western NY
    1,561
    Re: Electrical question for a layman like me.
    On all of the electrical devices there will be some sort of power requirement data tag. It will have both the voltage and the amperage listed. We will need both of these numbers to help with this from all devices.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    22,551
    We've been having an unusually hot and humid summer this year as compared to last year, so I don't think it's necessarily the pool that's using all the additional power. I know my power bill has taken a jump and I have had the pool for several years.
    Jun 2012
    western NY
    1,561
    Quote Originally Posted by Bama Rambler View Post
    We've been having an unusually hot and humid summer this year as compared to last year, .
    any time you want to send some of that my way, feel free to.
    Mar 2015
    Harvey, LA
    300
    Quote Originally Posted by danpik View Post
    Heat index here today is 115...if I could send some your way, I would package it up via fedex overnight immediately.
    Quote Originally Posted by ITR View Post
    If you have a clamp on amp meter, you could test the true amp draw for the pump at high and low speed...I concur with others on here that if you're only running the pump two hours a day, that is not where your extra consumption is coming from.
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    It's the Clear o3. I might be wrong but; you really shouldn't have ozone anyway, so turning it off will only help your situation.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mar 2015
    Harvey, LA
    300
    Quote Originally Posted by pabeader View Post
    According this manual (http://www.1paramount.com/products/a...arO3Manual.pdf page 6 of the pdf) the o3 only uses 1.5 amps...You aren't running the clear o3 outside of the times you are running the pump are you?
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    The clearO3 is on the same relay as the pump. It's not that (although I wish I knew everyone advised against them before I built). Bama and Gilbee, I think you guys are right. I did the calculation and the lights would only use 8 kWh all month. I checked my nest reports from last year and my AC is definitely working more this year. Thanks for the insight and helping me understand this. I should have checked that first. Here in FL our AC is a good chunk of the bill (especially since I have a tankless water heater). Looks like you guys hit the nail on the head.
