Thread: pebbletec"stained"
    Sep 2012
    Lake Nona, Florida
    386
    pebbletec"stained"
    We've had our pool for a few years now (wow time flies)... and my wife has noticed that the horizontal surfaces are starting to develop darker spots in the pebbletec. She is going to call the guy who did the install but I'm curious of other ideas. To me it looks like the light colored plaster that binds up the stones is wearing away ever so slightly and more dark stone is showing now. It is also possible that the light colored part is staining somehow. I thought that the fact that this is more noticeable on the horizontal surfaces could mean something is settling out and staining.
    I think our chemistry has been OK. We have had several bouts with heavy rain, pumping and needing to work to get the pool to hold chlorine levels again, but it's never turned green and we have always gotten it to balance out again in a few days. I'm not sure what else to check. Hope the installer has ideas. It is not bad now but I'd like to stop whatever is happening from getting worse.
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: pebbletec"stained"
    Oh bummer, davelinde I remember following your pool build like it was yesterday.
    Just a thought- got a robot or pool cleaner that gets "stuck" in one or so darker areas of the pool and scrubs away too long maybe on those areas?? I don't even know if that's possible but I'm trying to play detective here..... ?
    May 2015
    spring hill, FL
    40
    When I built my pool, I was told that pebbletec actually gets darker, more vibrant with more brushing, because the stones do show through more and more over time. I did not go with pebbletec at the time, but I was told it lasts 25+ years
    12k in ground, 14x28 sports pool, concrete/plaster/diamond brite, uncovered
    Waterway 1.5hp pump, waterway 150sqft cartridge filter, auto chlorinator, on city water, Zodiac MX8
    Sep 2012
    Lake Nona, Florida
    386
    I had to see my own sig to realize this is actually a stonescapes not pebbletec btw.
    To clarify I don't actually find the darkening objectionable but the wife is worried so I am too. My first feeling IS that we are just seeing a little more stone now, but if it is a chemistry issue causing it to darken we could do something I guess.
    And btw - I ALSO feel like we built this just the other day. Time flies...
    JoyfulNoise's Avatar
    May 2015
    13,176
    You could try to test the areas with vitamin C and trichlor tablets to see if the "stain" lightens at all. If neither test is positive then it could be calcium scaling (calcium scale sometimes can be dark colored if it incorporates "dirt" in it or if there is significant magnesium levels) or the cement has eroded in that area (either physical or chemical) and the aggregate is more exposed.
    Do you pour any chemicals in near that area?
    Matt
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    What's your CH?
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
