Results 1 to 7 of 7
Thread: Salt Reading
    Aug 2015
    Vancouver, BC
    7
    Salt Reading
    My SWG reads 2800, but a pool tech with a salt pen the other week told me his read 3400. I realize that both are calibrated units, but which one to trust, and how to get an actual correct reading? Thanks
    16x38 - Approx 27,000 Gal, IG, Vinyl liner, Sand filter
    Hayward 3/4hp SP2605X7A, Hayward Variflow XL / S-244T
    Hayward Aqua Rite XL SWG / Aqua Solar w/ GVA-24
    Hayward H-350
    City water with Septic
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Salt Reading
    not familiar with the salt pen, but even the Taylor salt test is +/- 200ppm and its considered the most accurate. honestly if your SWCG is happy and generating FC I wouldn't worry about it. if you are getting a high or low warning on your SWCG then need to investigate. the Taylor drop test for salt is the best one available. about $25 I think
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Aug 2015
    Vancouver, BC
    7
    Re: Salt Reading
    Thank you! It is happy - and I am not getting corrosion. I will look into the Taylor test.
    Hayward H-350
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Re: Salt Reading
    Yeah, as long as your swg is happy, then its really irrelevent as to what the level is.
    I have the Taylor K1766 and its a very handy test kit to have.
    Divin Dave,
    Aug 2015
    Vancouver, BC
    7
    Re: Salt Reading
    Dave, is the Taylor test kit the same technology that gets used when I take my water sample into the pool store?
    Hayward H-350
    Jul 2015
    Western NC
    115
    Re: Salt Reading
    The pool store that convinced me to find this place used test strips and some sort of scanner which I assume was connected to a computer.
    The mentioned Taylor K1766 test is a drop test for salt only, so it's not what is usually referred to as a "test kit" around here. (It's very useful to find your approximate salt concentration, though)
    A test kit, e.g the TF-100, allows you to monitor several important parameters including free chlorine (FC), combined chlorine (CC), pH and cyanuric acid (CYA).
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    30,431
    Re: Salt Reading
    Hard to say because we don't know what they use.
