Results 1 to 10 of 10
Thread: Draining Pool?
    Aug 2015
    Vancouver, BC
    7
    Draining Pool?
    I didn't know exactly what category to put this question in.... How do I handle draining the pool when it comes time to replace the liner? It is an old pool with no bottom drain. I am on a septic system, even though I am in an urban setting. My drain for waste goes under my front side lawn, but, there is no place to evacuate 27,000 gallons without disrupting something...
    Does anyone have experience with a pumping service that can pump it into a truck? Also, can I refill the pool with a truck, or is the flow rate of the water disruptive to the settling of the liner?
    Thank you
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    Re: Draining Pool?
    My city requires drained pool water to go thru the septic system. I bought a submersible sump pump from Lowes and a 100' heavy duty hose and drained mine right into the clean out in the front yard. Took about a day, but I only have 5000gal.
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Aug 2015
    Vancouver, BC
    7
    Re: Draining Pool?
    Thank you for the reply. We too have laws against draining treated water into stormwater drains. When I drain my hot tub, I just route the hose to my back garden but I am afraid 27,000 gal of saltwater would inundate both my waste drain and my septic field - not to mention kill some vegetation at the very least...
    16x38 - Approx 27,000 Gal, IG, Vinyl liner, Sand filter
    Hayward 3/4hp SP2605X7A, Hayward Variflow XL / S-244T
    Hayward Aqua Rite XL SWG / Aqua Solar w/ GVA-24
    Hayward H-350
    City water with Septic
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Draining Pool?
    Wait for a rain storm. Then no one can see you discharging it out into the street.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Draining Pool?
    If you want to replace the liner, you could empty the pool in increments couldnt you? Well, at least if you owned the submersible pump I would think so. If you aren't in a hurry. 4 or 5 thousand gallons into the septic every so often until its empty?
    Divin Dave,
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Draining Pool?
    Are you on a well too ?? I'd ask whoever you are planning to use for an installer their thoughts on how best to drain and fill it in your area with your laws/restirctions. I would think something coming out of a big hose from a truck might not be the best way to go for filling with a liner. Just MHO.
    Solar Blanket, Well Water, Borax Added. 68
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Re: Draining Pool?
    Call your fire house and see if they can pump and take the water?
    Kim
    Aug 2015
    Vancouver, BC
    7
    Re: Draining Pool?
    Yes, Frog, my thoughts exactly - that the pressure from the truck fill may not be the best for the liner. Dave, that is a good suggestion about increments...never thought about that.
    It is really not so much about "what is allowed" and more that a huge amount of chlorinated water can't be good for anything in the environment....I have never really thought about this, as I never had to deal with it, but there needs to be a company that rents you a tank to sit in your driveway and "hold" your treated water until you are ready to dump it back into the pool again...
    Hayward H-350
    Jul 2015
    Western NC
    115
    Re: Draining Pool?
    27,000 gallons of water = more than 100 tons
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    Jun 2015
    Charlotte NC
    225
    Re: Draining Pool?
    Quote Originally Posted by CDNpoolster View Post
    Sorry, I actually meant to say thru the sewer system, not septic. And I see in your signature now, that you are on a septic system. Yeah, 27K gal would be a lot and would flood your system for sure. Seems like your only 2 options would be draining in increments or a "holding tank" type system. Please let us know what you decide or do. This info may be helpful to someone else in the future.
    Ant
