Results 1 to 13 of 13
Thread: Pool Cleaner Question!
    hellstorm2004's Avatar
    Jul 2015
    Richardson, Texas
    182
    Hello Everyone,
    My second thread! Thanks to all who helped me out with the first!
    After the landscaping guys messed up my pool, I almost got the pool clean, but doing it with a vacuum in this heat is tough. I only have about 25% or dirt and debris left over now. But the thing is. it is getting a bit annoying to vacuum the pool at every chance i get, its putting my other chores on hold. Would a automatic pool cleaner help in this matter. I will need it in future anyway, so thought that this would be the right time to buy it.
    Can you suggest me some good options. I would like a low down on the different types of them too. Mostly looking into pressure or robotic. After reading through guides, the suction versions don't seem to be promising.
    Purex Titron FNS DE Filter 25000 gallons approx.
    Century A.O. Smith B855 56Y 2HP Motor. 40x25 (approx). Plaster surface.
    TFT-100 Test Kit.
    Rainbow Lifeguard 320.
    DX5+S Cleaner.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Pool Cleaner Question!
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jul 2015
    Richardson, Texas
    182
    Yeah i read that. But considering what i read, mine is 40 feet long, is that considered a "big" pool?
    EDIT: Please don't suggest Aquabots, they look like ugly alien buggies! Polaris ones are cool!
    TFT-100 Test Kit.
    DX5+S Cleaner.
    Jul 2015
    Richardson, Texas
    182
    After looking at online, these two seem a good option:
    Dolphin DX4
    Hayward SharkVac RC9742.
    Any opinions on these?
    TFT-100 Test Kit.
    DX5+S Cleaner.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    A member posted this link before, something to take in account...
    http://www.sunplay.com/blog/the-trut...t-telling-you/
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Hayward and Dolphin robotic cleaners will get the job done. You could also look into the Nautilus and Nautilus Plus from Dolphin as well. 40' long would be a big pool.
    Isolated Spa - 345 Gallons
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by hellstorm2004 View Post
    But they have great personalities!
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jul 2015
    Richardson, Texas
    182
    @Piolin: Thanks!
    Yeah, i was reading that Aquabot virtually invented the segment. That is something! My edges of the pool rounded and not 90 degrees. Do i have to take that into account? Or it doesn't matter to a robot?
    I will look into Dolphin Nautilus and one more i found is the Dolphin M500.
    Two more questions:
    1. Is having a remote a big deal?
    2. And what is the caddy used for? Isn't the cleaner left in the pool at all times?
    TFT-100 Test Kit.
    DX5+S Cleaner.
    Jun 2014
    Long Island, NY
    340
    RE: Remote, I cant say as I dont have one,My Ab seems to get all of the pool. I'm sure some who have remotes will jump in
    Caddy: yes, some people leave them in all the time, I do, But if you want to take it out often the caddy keep everything in it's place.
    BTW, check out the Gallons you have listed in your Sig, @ 40x25 it should be closer to 25,000 plus- i think a 0 dropped?
    Jul 2015
    Richardson, Texas
    182
    Quote Originally Posted by EVChargeGuy View Post
    Ooops! I will correct it!
    TFT-100 Test Kit.
    DX5+S Cleaner.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    a pool robot will work better on a rounded corner than a square one.
    Divin Dave,
    Jun 2015
    Raleigh
    357
    We have the less expensive Dolphin m200 and it rocks. It climbs walls like no other and will actually travel laterally along the wall and even around the corner. Our PB watched ours as we were one of the first to get one and he remarked it climbs much better than the more expensive m400.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Jul 2015
    Richardson, Texas
    182
    The thing about these cleaners are its prices. The price varies from site to site! Its weird. Also i read that if i buy online warranty will be void. Is that true?
    TFT-100 Test Kit.
    DX5+S Cleaner.
