Results 1 to 12 of 12
Thread: Test Results: High Alkalinity, Saltwater system
    Aug 2015
    Allegan, MI
    9
    New Intex Easy Set pool in direct sunlight, although been cloudy the past two days and raining overnight and today. Just filled in the past two days from spigot from house that has a water softener system. Using saltwater pump and standard pool filter that came with the pool. Today is 3rd day with water in. Filter/saltwater pumps have been running about 12 hours total. For size of pool, salt machine directions say we need to run it for 80 hours.
    Color looks a bit off today.
    Test results:
    Chlorine=1
    PH=7.2
    Alkalinity=240
    Calcium=0
    Do we need to do anything or simply wait for the water to cycle for the length of time recommended?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Test Results: High Alkalinity, Saltwater system
    Check out ABCs of Pool Water Chemistry. Have you added any solid chlorine products or stabilizer for the pool? This is a great guide to go by for small, seasonal pools once you've ready through the ABCs: Pool School - Guide for Seasonal/Temporary Pools
    Short answer: You need more chlorine and some stabilizer in the pool if you have none.
    Isolated Spa - 345 Gallons
    Aug 2015
    Allegan, MI
    9
    Quote Originally Posted by JVTrain View Post
    Thank you for the info!
    Feb 2014
    Central Minnesota
    5,080
    No problem. You should start it up as the seasonal guide recommends. Be sure when adding the stabilizer (aka CYA or cyanuric acid) to put it into a sock or stocking and hang it in front of a return. It takes time to dissolve and if you simply dump it in the pool, it will settle on the bottom and bleach the surface of the pool. Use regular, unscented bleach to get your chlorine level to 4 ppm. It's important to get it up ASAP. If it's already cloudy, you might want to add even a bit more. Use the Pool Math link at the top of the page to figure out how much bleach to add (and CYA first) based on your pool volume. Once you get some chlorine in there, then you can add the pool salt (have you added it yet?) and start to rely on the salt water chlorine generator and adjust your pump run time to keep enough chlorine in the pool from your generator.
    Aug 2015
    Allegan, MI
    9
    Yes, we added the salt last night about 6 pm. Now should we add the bleach according to the pool math and the CYA? Which one first?
    Feb 2014
    Central Minnesota
    5,080
    Bleach ASAP. CYA in a sock, in front of a return right after you add bleach is fine. It will take several days for the CYA to dissolve.
    Aug 2015
    Allegan, MI
    9
    Thank you so much! Hubby is on it right now! Much appreciated.
    Aug 2015
    Allegan, MI
    9
    Sorry, another question: We did all you suggested. How long before we will see a difference? Should we keep running our filter and SWG?
    Feb 2014
    Central Minnesota
    5,080
    You should run the pump/filter until the CYA is dissolved. How cloudy is the pool? Can you see the bottom clearly or not? If you have a good amount of haze, you may want to bump the FC to closer to 10 for a day or 2. Without a full FAS-DPD chlorine test, you can't really properly SLAM (see link in my signature) the pool but going to an elevated FC at about 10 for a day or more can sometimes be enough if it's a mild haze. Of course, your test kit, which I'm assuming is a 3-way color match test kit, cannot test at FC levels above 5.
    Aug 2015
    Allegan, MI
    9
    Funny thing, it's not hazy or cloudy really, but clear green. I have a 4-way test that will test up to 10 FC, 8.4 pH, 240 TA and 1000 CA.
    My current readings are
    FC=5
    pH=6.8 (expected with what I added today, right?)
    TA=160 (came down, but do I need it to come down more?)
    CH=somewhere between 0-100 but test right out of the pool was 0 and 60 seconds later was somewhere in between 0-100.
    Still running the filter and SWG. Should I keep the SWG and the filter pump on still?
    Maybe I need a higher FC?
    I'm pretty sure I need a PhD in chemistry to get this pool right. lol
    Would a photo help?
    Jul 2014
    Hope Mills, NC
    567
    You don't need a degree, just a TF100 test kit. It is really easy and really accurate, a thousand times better than the 4-way strips.
    Your numbers now are pretty useless.
    What the TFP process does is only concentrate on the 3 most important things (CYA, chlorine ond pH) and once you get them right the rest is gravy.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Aug 2015
    Allegan, MI
    9
    So hubby went to the local pool company today and our water has iron in it. Softener must have been overtaxed when filling and didn't regenerate fast enough for the load. He bought some stuff that takes the iron out and a couple better filters to swap out and rinse off and the pool looks 50% better. We can't swim for a coupe days and they said by this weekend, it will be clear and iron gone.
