Thread: Repairing Pool Tile Grout - Above and Below the Water Line
    Jul 2015
    Ottawa
    3
    Hi,
    I am have some pool tiles where the grout has come out in a line of tiles near the skimmer basket. Water is slowly leaking out of the pool through this crack so I need to repair it. Does anyone have a recommendation on what product to use to fill this grout line crack that is about 1/4" wide?
    Thanks in advance.
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    Re: Repairing Pool Tile Grout - Above and Below the Water Line
    I'd drain the water level down below the problem area, clean out the joints and regrout with sanded epoxy grout. It's tougher than a $2 steak, impervious to chemicals and completely cures in a couple hours.
    You should be able to find it anywhere that sells tile.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Sep 2009
    Houston, TX
    117
    If water is leaking out of the pool I would think you have to fix more than just the missing grout...ie your shell has a crack that needs filled. Just patching the missing grout would not solve your problem at least in the long term as water will eventually migrate behind the tile again. I think the best course of action here be to remove the tile, fix the crack, replace tile and regrout. I'm no expert so hopefully someone else chimes in for confirmation.
    15000 Gallons In ground, Ecobright pool finish, sand filter, Pentair intelliflo VS, SWG
