Thread: Adding stablizer granules to skimmer DE filter root of issues?
    Aug 2015
    Boston, MA
    32
    Hello all,
    I am wondering if by pouring stabilizer granules into both skimmer baskets has caused my DE filter to leak at top and middle of it? Could that possibly be causing issues at the filter level that would cause leaks to it? Live and learn this season ugh. First pool.
    IG 15 X 30 Rectangle Vinyl Liner Built 1994
    Hayward DE 3620 Vertical Pro Grid
    AquaCal Heat Pump
    18K gallons
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Adding stablizer granules to skimmer DE filter root of issues?
    Did you put the granules in a sock or just pour them in the skimmers? If you just poured them directly in the skimmers, I would say that it could be a possibility if they passed through in granular form. I am not certain though. I hope you figure it out.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
