Thread: Construction thread - multiple questions
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Not sure where to post this. Not really an issue, but I have some questions about updating threads. Didn't see these answered in the Pool Rules section.
    We're in the process of building a pool. Just signed the contract and are awaiting inspections and permits and such. We will undoubtedly have many questions along the way.
    Is it standard or recommended practice to update the title of the thread as new questions come up or as we change build phase?
    Is it standard or recommended practice to update the OP with the new questions as well as post in the flow of the discussion?
    Thanks!
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Construction thread - multiple questions
    Just put "gunite pool build in woodlands tx" or something of that nature as the thread, then ask away... when you come to a new questions, just hit reply and on the first line ask the new question.
    This was my new thread where I went from 1 pool to another and questions along the way
    New above ground oval 18x33 install
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    When you start a build thread you are allowed to discuss all issues associated with the build in that thread without having to edit the title. It makes it much easier for members to follow your thread if the title remains the same. Build threads are usually many pages long and if you update the op that info will probably be missed by those that have been following the thread, and may make the thread more difficult to understand for those who start reading after several pages have been published.
    Love TFP? Become a
    TFP Supporter!
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Quote Originally Posted by zea3 View Post
    Thanks. I was thinking that keeping the OP accurate would lead to less confusion. But maybe not. I'll leave the OP as is and just update in the thread.
    Build thread
