Thread: Don't even know what the skimmer is.....
    Aug 2015
    Norfolk, VA
    1
    Hi everyone. My name is missinandre and I need help. My daughter got a swimming pool for making the "A" honor roll all year round and I don't even know what size it is but it is an intex vinyl pool that holds a little over 5 thousand gallons. I need to know what the skimmer is....a recommendation for a vacuum, advice for getting rid of swampy green water and....I'm preparing myself for winterizing her pool. No way am I taking it down and packing it up! Thanks!
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Don't even know what the skimmer is.....
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Congrats on the new pool!
    A skimmer is a device that skims leaves and debris off the surface of the water. Intex makes one that hangs og0ver the pool wall or you can cut a hole in the side of your liner to install one.
    Here are articles from Pool School about closing and opening your pool.
    Pool School - Closing (Winterizing) Your Above Ground Pool
    Pool School - Opening Your Winterized Above Ground Pool
