Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: HIGH FC Reading!
    Jul 2015
    Greenville, SC
    19
    HIGH FC Reading!
    I'm panicking a little ...
    Here are my current test results.
    *using TF-100 test kit*
    pH 7.5
    TA 60
    FC 18 *** tested twice!!!!***
    CC 0
    TC 18 ***
    CYA 50
    CH 225
    My SWG was at 68% .. I immediately reduced to 40% after this reading.
    Should I do anything else immediately?!?!?
    16x36 IG Vinyl (25k gallons), Pentair Sand Dollar Filter SD60, Intellichlor IC40 SWG, Intelliflo Superflo VS Pump, Polaris 360 Cleaner
    38,524
    Re: HIGH FC Reading!
    Nope. That is still below shock level and safe to swim in.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    It is safe to swim when FC is between minimum level and shock level for your CYA level. Chlorine CYA Chart
    Jul 2015
    Greenville, SC
    19
    Ok .. So adjusting the SWG should do the trick? We've even had lots of rain and its jumped from 11-18 in 5 days.
    JoyfulNoise's Avatar
    May 2015
    13,254
    Since you're running an SWG, your CYA should be higher, it should be closer to 70ppm. Don't worry about the FC, it will come down on its own and your level is not that high.
    However, I wouldn't put too much stock in your pH measurement. At an FC higher than 10ppm, the pH indicator dye is not accurate. Retest your levels when your FC drops below 10ppm.
    Matt
    Jul 2015
    Greenville, SC
    19
    Thank you!!!
    Quote Originally Posted by pooldv View Post
    Jul 2015
    Greenville, SC
    19
    I agree with the CYA reading. Thanks for the help!!!
    Jul 2015
    Greenville, SC
    19
    8/11/15 reading :
    *only tested chlorine*
    FC 14
    CC .5
    TC 14.5
    8/13/15 reading :
    pH (didn't test)
    TA 60
    FC 12
    CC .5
    TC 12.5
    CYA 40
    CH 200
    8/16/15 reading :
    pH 7.5 (possibly inaccurate b/c of high FC reading)
    TA 60
    FC 14
    CC 0
    TC 14
    CYA 50
    CH 225
    SWG has been at 40% since 8/9/15. Why is FC jumping back up? Should I lower SWG more? I'm so new at this and I know I ask basic questions. I have read information on Pool School. I know what readings SHOULD be, but I don't know how to make them get to those ideal readings. Help would be greatly appreciated!
    May 2015
    13,254
    What is the volume of your pool?
    What model intellichlor do you have (IC-20, -40, or -60)?
    Matt
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Quote Originally Posted by khsjes27 View Post
    8/11/15 reading :
    FC 14
    CC .5
    TC 14.5
    8/13/15 reading :
    pH (didn't test)
    TA 60
    FC 12
    CC .5
    TC 12.5
    CYA 40
    CH 200
    8/16/15 reading :
    TA 60
    FC 14
    CC 0
    TC 14
    CYA 50
    CH 225
    If you added CYA- and it looks like it since it went up - that would account for the FC sticking around longer and building up.
    Just reduce the filter time or the SWG on time. Personally, I'd start by cutting the filter down an hour, because that will save a lot more money on electricity than just reducing the SWG on time. The SWG percentage is just like the power level on the microwave. 50% means on half the time, off half the time. 40% means on 40% of the time. But it will only run when it has flow, which means the pump has to be on. If you're running 8 hours pump at 40% SWG, that's the same as 4 hours pump at 80% SWG or some multiple thereof.
    The pool is still swimmable, so don't get so anxious. It's all about learning your pool's personality. You only joined TFP last month! You're doing great! Another couple of weeks of experimenting and you'll be bored with pool maintenance and will start trawling the forum looking for someone else's problem to solve.
    Jul 2015
    Greenville, SC
    19
    It is an IC40. I have a 16x36 rectangle. I still can't figure out exact volume. I'm thinking 25,000. We have a 3.5ft shallow end that goes to 8ft deep end.
    DFW, TX
    24,514
    Please add your pool info to your signature as shown here, Pool School - Read This BEFORE You Post
    May 2015
    13,254
    24,800 gallons by PoolMath....call it 25,000.
    Do as Richard320 says. Start cutting back your pump run time by an hour. Wait a few days. Check your FC. If it is not low enough, cut out another hour. Repeat as needed.
    Matt
    Jul 2015
    Greenville, SC
    19
    It's almost like you know me!! (The anxious part describes me perfectly!) 😁
    I did add stabilizer because I felt it needed to be higher and so did another user in this thread
    We run the pump at high speed from 3-11 each day .. so I think you might have just helped with the issue tremendously. 8 hours high speed at 40% is like 4 hours at 80% ... which is exactly what we were doing!
    I can't wait till I can start trolling the forum and help newbies like me!! Might be a while though -- maybe next season!
    Thank you!!
    Thank you!!!!
    Jul 2015
    Greenville, SC
    19
    Also, any suggestions on pump speeds during low & high speeds. Currently our low speed is 2200rpm and high speed from 3pm-9pm (just changed) is 2700rpm. Last question for the night THANKS!!!!!
    May 2015
    13,254
    What are the purposes of the split speeds? What is your pool doing?
    Matt
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    I've read a number of posts that suggest as low as 1100 rpm or even lower for slow speed. It's just enough to keep stuff moving but lowers the electric bill quite a bit.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Richard320's Avatar
    Jan 2010
    19,071
    Can;t help there. I'm a Luddite. I still have a single speed pump with a mechanical timer and manual valves.
    Jul 2015
    Greenville, SC
    19
    Let me preface this by saying that the company that installed our pool did NOT "balance" our pool water when the job was completed .. that's another story for another day �� ... Anyway, they set the pump at 1400rpm but it seemed that the pool was cloudy. *of course it was .. It wasn't balanced* So we (the newbies ��) adjusted the pump speed UP after seeing that the water was cloudy. But really have no explanation for why we set it where we did ... Just being honest here
  20. Back To Top    #20
    May 2015
    13,254
    Let me ask it a different way - aside from the salt water chlorine generator, is there anything else in your pool that you need to run? Examples would be - in-floor cleaning system, suction or pressure side cleaners, water features like waterfalls or bubblers, deck jets, or an attached spa?
    How many skimmers, main drains and returns do you have?
    And what model and size sand filter do you have?
    Matt
