Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: What is causing my daughter's fingertips to peel during and after swimming?
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Anyone else encountered this? Does it have to do with the bleach?
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    Jun 2015
    N Tonawanda, NY
    474
    Re: What is causing my daughter's fingertips to peel during and after swimming?
    Just being in water a long time can make your fingertips all wrinkly. Is she a beginner swimmer who may be grapping onto the edge of the pool a lot?
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Can you post a full set of results from your test kit?
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    No, she's an advanced swimmer. She's a fish.
    Latest test results:
    FC: 8.5 (bumped up due to high swimmer load this weekend)
    CC: 0
    pH: 7.5
    TA: 130
    CH: 200
    CYA: 40
    Wendy
    TF-100 Test Kit
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    TA is a little high, but I don't see anything to cause this problem, how your water look?
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    It's sparkly clear.
    Wendy
    TF-100 Test Kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    how about a pic of your daughters fingers?
    Divin Dave,
    Jan 2012
    'burbs of Augusta, Georgia
    7,359
    Does she peel when visiting the ocean? Does she play sports or a musical instrument that causes callus build up on her fingertips? Just her fingers and not toes too?
    Is it actual skin peeling or just pruning up? What does the fingertip underneath the peeled area look like??
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    The one is still peeling from tonight's swim. The others have peeled and are just red now.
    Quote Originally Posted by YippeeSkippy View Post
    No, only in our pool. And no, no sports or musical instruments. My son doesn't have this issue, nor anyone else that's swam here, that I know of.
    Wendy
    TF-100 Test Kit
    Jan 2012
    7,359
    I'd have to wonder if she's gripping something or scraping her fingers on some edge of the pool to look like that? I know some plaster pools can be a tad rough on some folk's feet....?
    Pain? Itching?
    Orlando, FL
    690
    Quote Originally Posted by wjaneala View Post
    People react differently to pools and chemicals sometimes. I have never had peeling fingertips but when I used to swim five days per week, one hour a day, a strange thing would happen to me. At least 3-4 times per week, after swimming for about 30 minutes, I would get a pain in my head that was so terrible that I thought I was having an aneurysm. I would get out of the pool and go sit in the hot tub until it subsided. Doc had no explanation and neither did Google. Now, it seems they are calling it a swimmers migrane. The after effects were definitively those of a migraine and they lasted for several days.
    It is awful when something happens and you cannot figure out why. It may be that she is a bit sensitive to the chlorine and it is drying her skin. Have you tried Eucerin or Aveno?
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Pain? Itching?
    No plaster. We have vinyl. The only things she handles are pool noodles, floats and a beach ball. No itching, but she says they are painful.
    Quote Originally Posted by f3justusc View Post
    People react differently to pools and chemicals sometimes. I have never had peeling fingertips but when I used to swim five days per week, one hour a day, a strange thing would happen to me. At least 3-4 times per week, after swimming for about 30 minutes, I would get a pain in my head that was so terrible that I thought I was having an anueris. I would get out of the pool and go sit in the hot tub until it subsided. Doc had no explanation and neither did Google. Now, it seems they are calling it a swimmers migrane. The after effects are definitively those of a migraine and they last for several days.
    It is awful when something happens and you cannot figure out why. It may be that she is a bit sensitive to the chlorine and it is drying get skin. Have you tried Eucerin or Aveno?
    Trying Aveeno tonight. Will see how they look in the morning.
    Wendy
    TF-100 Test Kit
    Orlando, FL
    690
    Could also be coincidental. The fact that they are painful would make me wonder if this is not at all related to the pool. Just my two cents.
    Jan 2012
    7,359
    How old is your daughter, if I may ask?
    Jul 2012
    Whidbey Island, WA
    397
    some other info?
    what is the water temperature?
    how long is she in it?
    does she notice anything when reaching into a freezer and removing cold items?
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Mar 2007
    San Rafael, CA USA
    12,082
    With a 36,000 gallon pool you shouldn't need to bump up the FC as much as you are. The minimum FC for 40 ppm CYA is 3 ppm so your 8 ppm is on the high side. Normally not a problem, but you might as well try a lower target level. One person-hour in 36,000 gallons would only consume 0.03 ppm FC so even with 10 bathers for an hour or 5 for two hours it would only consume 0.3 ppm so you don't need to raise the FC very much at all.
    Nevertheless, 8 ppm FC with 40 ppm CYA is equivalent to 0.2 ppm FC with no CYA so far lower than in commercial/public pools with no CYA such as some indoor pools.
    Are you sure the CYA is at 40 ppm? Are you finding the daily chlorine loss to be around 2-3 ppm FC or is it substantially higher indicating that perhaps the CYA level is lower than you think?
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Oh yes. Very familiar with this.
    My son too is an avid swimmer - swim team and dive team. At the start of every swim season he gets (along with several other kids) what is called "pool toe." Depending upon how much diving he does from the side (rather than the boards) he will also come home with pool fingers. This is from diving from the side and rather than using the ladder to get out, he lifts himself out on the side because it's more convenient. There is usually some small amount of sand around the edge somewhere and if he is the only kid practicing from the side, it takes a several times for the water dripping from his shorts to wash it all away.
    Here's a bit of info Blisters on the finger tips and toes after swimming in a 6 year old boy? | Yahoo Answers
    Have her lather her hands with a good thick lotion (Eucerine cream in a jar/tub - Walmart generic works pretty well, but swing for the name brand to be safe) before and after swimming. She might have used an exfoliant, or soap with antibacterial beads that that took just enough skin off to make her hands more delicate today.
    Hope the hurt stops soon! We have kids every summer who suddenly erupt from the pool in tears because it hurts so bad.
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    She is 12.
    Quote Originally Posted by engrav View Post
    some other info?
    Temp today was 90, and she was in for a couple of hours. The freezer thing, no.
    Quote Originally Posted by chem geek View Post
    We had about 15 people in there for a few hours on Saturday. Just letting it drift back down now.
    I'm pretty sure it's 40, unless I'm doing the test incorrectly. I find that I lose anywhere from 2-4 ppm FC each day, depending on the weather. The pool is in full sun all day long.
    Quote Originally Posted by Household6 View Post
    Thank you for the info! She does dive quite a bit, and she always pulls herself up and out on the side of the pool, rather than using the ladder or steps. Our pool deck is concrete, so maybe that has a lot to do with it?
    Wendy
    TF-100 Test Kit
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Yup, I'd think it does.
    Her feet are better acclimated and have developed thicker skin.
    20x40 in-ground concrete "vintage" pool
    Approx 35k gal
    Concrete, plaster and epoxy paint
    Sand filter
    DIY plaster resurface repairs completed 6/2015.
  20. Back To Top    #20
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    It's definitely the concrete. My oldest daughter is 8, and her fingers looked exactly like that at the beginning of this swim season. She too was holding and pulling up on the side. Pruny fingers and brushed concrete don't mix well at all.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
