Results 1 to 14 of 14
Thread: Hose bib above pump
    bluetahoe's Avatar
    Sep 2014
    La Vernia, Tx
    34
    Hose bib above pump
    Hi guys, I have a rather benign question. Our pool installer placed a hose bib about 8 inches above the pump in the pool plumbing, between the pump and filter. I can't figure out what I would use that for or why it would be necessary. Drain water from the filter maybe? Thanks for any answers.
    16x32 rectangular, 19,000 gal, gunite, quartzscapes plaster, Hayward Tristar 2 speed 1.5hp pump, 31" Hayward Pro Series sand filter, TF-100 test kit, BBB method rocks
    38,475
    Re: Hose bib above pump
    I think it is sometimes added when they pressure test the lines. It is a nice easy way to partially drain water if you need to ... or hook a hose to it and dominate the squirt gun fights in the pool
    bluetahoe's Avatar
    Sep 2014
    La Vernia, Tx
    34
    Hahaha...thx blizzle.
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    I'd bet it would as handy as a pocket on a shirt for priming the pump without removing the lid- hook it up with a washing machine hose ( female bibs on each end) to a regular garden hose and prime away. It would also be handy for getting your water test samples.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    bluetahoe's Avatar
    Sep 2014
    La Vernia, Tx
    34
    Ahhh. My pool guy was smarter than I thought. Thanks thimble.
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    NP, bluetahoe. I think I'll get me a saddle T and put one in my system.
    Jun 2015
    Wildomar, California
    423
    Here in Calif. It's to drain water from the pool. Which is idiotic because it never rains here. LOL!
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    I have one too, and as mentioned, it's a handy way to drain if you don't have a lot to drain. Can use the water hose to run a sprinkler too.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Jul 2015
    Long Island City, NY
    70
    I always thought the hose bib was used to blow out the lines for winterization or repair?
    Dec 2012
    Manassas Park, VA
    207
    I found that it is useful to release some of the pressure if I have trouble removing the pump lid.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Quote Originally Posted by Thimble View Post
    I don't think I'd rely on it for water samples as it kind of goes against the convention of dipping in one's sample bottle 12"+ below the waterline but it could keep one a tad drier.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by OldPoolMan View Post
    But it does make it easy to connect a sprinkler to water the lawn to reduce CH buildup.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Ah, excellent point! Doggone it...wish I had plumbed one in. Now I gotta see where I might be able to sneak one in....
    ----Chris----
    38,475
    When I redid my pad plumbing I meant to plumb one in. . But then I went and forgot.
