Results 1 to 19 of 19
Thread: Signing tomorrow morning. Quick question
    Jul 2015
    Ooltewah, TN
    93
    All, thanks again.
    Is a 2-speed Hayward Tri-Star pump worth the $500-$600 up charge over a Hayward Tri-Star 1.85 pump?
    Sure I have seen what the paperwork says...but really? What's the difference in electric?
    This is for a 20x35 grecian. 4-5-4.
    38,235
    Re: Signing tomorrow morning. Quick question
    That is kind of expensive for a upgrade from a single to 2-speed. The pumps are only around $200 difference in price. Install is the same, although a little more electrical to add a switch (unless you have automation too).
    Pretty easy to save over 50% of the electrical cost to run the pump.
    I would argue that the pump price difference is only ~$200 and suggest they upgrade you for $300-400.
    Jul 2015
    Ooltewah, TN
    93
    Certainly don't mind saving on electric for several years...but paperwork is rarely real life conditions...
    But if 50% cheaper to run, heck it's worth it on the front end. I will certainly ask for a cheaper rate.
    38,235
    On low speed, they move about 1/2 the water as on high speed (which is the same as a single speed), but on low only use 1/4 the electricity.
    If they are adding a timer to control the speeds, that could be part of the cost. Although pretty easy to switch it manually only when needed and leave it on low most of the time.
    Jul 2015
    Ooltewah, TN
    93
    Basically you really only need to run "high" when swimming, then low the rest of the time?
    38,235
    You only need high when backwashing or vacuuming.
    Jul 2015
    Ooltewah, TN
    93
    Interesting...
    Thanks! Just know some things sound good on paper, but in reality not all it's cracked up to be.
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Two thoughts from my POV:
    it costs $80/m to run our single speed pump 24/7. Especially during the winter, 24/7 isn't necessary (we keep it uncovered and kept up year around purely for esthetics).
    I heard a lot of negatives about pool timers and how often they break, so I never put one in. But what I wish I had was a switch inside the house so I could turn the pump on and off without have to freeze and crawl into the pump house in the winter.
    I can't imagine that adding a switch and a line in a shallow ditch from the pump to inside the house would be expensive ($200 maybe?) but I can guarantee that I'd have saved that much money on the electric in just a few months if I'd had the switch inside!
    20x40 in-ground concrete "vintage" pool
    Approx 35k gal
    Concrete, plaster and epoxy paint
    Sand filter
    DIY plaster resurface repairs completed 6/2015.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    An Intermatic pool time clock is very reliable and will last a long time.
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Quote Originally Posted by pooldv View Post
    EDIT: the last time I considered one was over 5 years ago. I should have prefaced my thoughts with that. But my point remains the same - have a convenient means to turn the pump on and off. It'll save a fair amount of cash.
    Approx 35k gal
    Sand filter
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    +1 on adding a simple timer if one isnt included with the install. If not, its a very easy DIY for very little cost and a lot of benefit for the sake of convenience.
    Intermatic T104R timer costs about 60ish dollars.
    Divin Dave,
    Jul 2015
    Ooltewah, TN
    93
    Got the upgrade to variable speed with timers. For $350
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    You will love the VS pump.
    Quote Originally Posted by wxguy23 View Post
    Divin Dave,
    DFW, TX
    24,450
    Yep, I love my VS pump!
    38,235
    Did you get a 2 speed pump or the VS pump? That's a good deal either way.
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    So when is the ground breaking ceremony?!
    Approx 35k gal
    Sand filter
    Jul 2015
    Ooltewah, TN
    93
    Hayward Tri-Star VS pump. 3200.
    Quote Originally Posted by Household6 View Post
    Was going to post when they broke ground, likely next Wednesday. But they were out drawing it up yesterday.
    20x35 Grecian
    990 sq foot of sandstone color stamped concrete
    with pump/etc in back left corner.
    Just hope I don't regret those trees! Pool is about 20-25' from the privacy fence and trees. Once they "fill" in, I will trim the parts hanging over the fence back. (I took out 3 large pine trees in May, which stunted the growth of the other trees).
    I may be forced to moved the natchez crepe myrtles, and loose the shade and beauty they create. The pool water is only 15-17 feet from the trunks.
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Sure you don't want to just use the blowup pool in the background instead?
    Approx 35k gal
    Sand filter
    Jul 2015
    Ooltewah, TN
    93
    That will become the family pool raft.
