Thread: Placement of Spa Side Remote
    Sep 2012
    Los Angeles
    99
    Hi all!
    I need a little advice on the placement of my spa side remote. I was going to place it inside the spa just above the water line, but the tile and the electrician both say that it usually goes on top of the coping. My buddy has one in his spa, and it is just under his coping, not on top. Any problems with this placement? I would rather do that than have it on top of the coping. I think it would just stick out there. Also, if it makes a difference, it is a Jandy product, four button.
    Thanks!
    Rectangular pool 28x16 and spa 8x7, 17,000 gallons, IG, Tropics Blue Mini-Pebble, Jandy 60 DE filter, saltwater cell, Jandy VS pump, 1.5 hp Jandy spa pump, 400k heater, 5' Sheer Descent with 1 hp Jandy pump, Jandy color LED lights. Build Thread
    Apr 2013
    Sacramento, CA
    2,769
    Re: Placement of Spa Side Remote
    Google the jandy installation manual -- you will see that jandy expects it to be installed in the tile line. But either location is ok. Ask the electrician if he has read the manual.
    Sep 2012
    Los Angeles
    99
    Perfect. Thank you!
