Results 1 to 10 of 10
Thread: how much manganese is bad in a pool
    Jul 2012
    Whidbey Island, WA
    397
    Using well water for pool fill
    In the well water manganese is .09 ppm
    Is this too much? What is too much?
    Searched but could not find levels, maybe I missed
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: how much manganese is bad in a pool
    We don't have a definitive level where staining would become a problem, mostly because it's far less common than iron and copper staining. Nevertheless, according to this paper the solubility of oxidized manganese as black/brown manganese dioxide (MnO2) is roughly 0.1 ppm Manganese at pH 7.0 and increases in solubility to 0.3 ppm at pH 8.4. This 0.1 ppm is also roughly the limit for when unoxidized manganese might precipitate as light gray manganese carbonate (MnCO3) at high pH (8.0). The manganese dioxide can also get oxidized by chlorine to permanganate ion (MnO4-) which is purple in color.
    So I would bet that you are OK though on the edge at 0.1 ppm but note that if you use your well water for refilling after evaporation that the manganese level could climb over time.
    Jul 2012
    Whidbey Island, WA
    397
    Thank you, got it
    We have had the well water tested. I think I will scoop up some pool water and have manganese measured.
    If I pay the freight for manganese I might as well add iron and copper. Should I measure any others while at it?
    Mar 2007
    San Rafael, CA USA
    12,082
    For metals that can cause staining, those are the three to worry about.
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by chem geek View Post
    thanks, got it
    will order 'em up
    Jul 2012
    Whidbey Island, WA
    397
    results are back
    Cu Fe and Mn are ND, not detectable; cool
    but a puzzle
    if the fill well water is .09 Mn how can the pool be ND Mn?
    from the web
    "Essentially, the oxidizing agent (chlorine) causes rapid oxidation or "rusting" of the dissolved iron and manganese causing it to precipitate out of the water and turn into a solid particle. The particle is then mechanically filtered out of the water."
    maybe this is where the Mn went
    Mar 2007
    San Rafael, CA USA
    12,082
    The oxidized manganese is still slightly soluble as I noted in my post so it shouldn't have precipitated and filtered out since you started with such a low level. If such testing were free, I'd send them a sample of your well water to see if they detect the 0.09 ppm manganese in it. At any rate, it sounds like you don't have anything to worry about.
    Jul 2012
    Whidbey Island, WA
    397
    Not free but not so much so will have well water re-tested.
    Thank you.
    Jul 2012
    Whidbey Island, WA
    397
    Mn value in well water returned, .057
    barely above established contamination level of .05
    will cease thinking about metals
    thank you all
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    ^ I want your well. Just sayin
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
