Page 1 of 4 1234 LastLast
Results 1 to 20 of 79
Thread: Ready to get started
    vol4life's Avatar
    Jul 2015
    Nashville, TN
    29
    I just got the TF100 in the mail. My pool water is green and I am in need of help! What readings do I need to post to receive help? I do not have a desktop so I cannot build a profile, my pool is 18x36 Approx. 29k gallons IG Plaster.
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Ready to get started
    A complete set- FC, CC, CH, pH, CYA, TA
    Bring us the numbers and we'll go from there.
    Also, what have you been putting in the pool so far? How do you chlorinate?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Set your numbers up like this please
    FC
    CC
    Ch
    PH
    TA
    CYA
    That makes it easier to read.
    Since you cannot set up a siggy please put the pool in each post to help us help you.
    Do you have bleach on hand to start your SLAM?
    Lets get this party started!!!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,975
    Welcome!
    You can do this. Besides test results, how about posting a picture? I'm always looking for good green-to-clean threads with pictures to go in my Inspirational Threads thread.
    vol4life's Avatar
    Jul 2015
    Nashville, TN
    29
    I am finally able to test my pool water but is about to rain! Should I wait!?
    Jul 2012
    Tallahassee, FL
    30,444
    What is a little rain? LOL Lighting stay inside, rain go out and grab a sample.
    The CYA might be hard for you to do as you will need sun but eveything else will work.
    I hold a white plate behind my PH test and pull it back and forth to help me see the color better.
    I do my tests at my stove a s I have a very bright light there. Just make sure you have good lighting where ever you test.
    Kim
    You can test your CYA just to see about what it is.
    vol4life's Avatar
    Jul 2015
    Nashville, TN
    29
    I couldn't wait any longer so I took a sample. The levels are as follows...
    FC .5
    CC.5
    CH 525
    PH 8.2
    TA 90
    CYA 40
    I did my CYA test inside with good lighting. Can I count on it? This was my first time using my TF100. My wife laughed at how excited I was to use it!
    I am dissapointed that my PH is so high. I had been using test strips and they obviously failed me....
    Let me know what to do!
    IG plaster Approx 29k gallons 18x36
    I would post pics but I am on mobile.
    Jul 2012
    Tallahassee, FL
    30,444
    First things first...............get that PH down. It might be even higher.
    Here is what to do for each thing. The one you are working on now is the getting the PH down.
    Add the MA SLOWLY in front of the return with the pump running. Make sure to wear some eye protection and do NOT breath it in.
    Let the pump run for 30 mins and retest. Do no be surprised if you see little lose. I am thinking it is going to take a couple/few tries to get it down.
    -test, add, run pump 30 mins. Repeat as needed. to get the PH down to 7.3.
    CYA should be okay for now.
    Kim
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Yup, get the pH down to 7.2-7.4 and be careful if using muratic acid as the fumes will choke you, literally. I like doing it at night as you can often see it smoke and see which way it's blowing. Try to stay upwind of your pour if at all possible.
    If you're reading 8.2 you might 8.3 or 9 something. 8.2 is pretty much the max measurement. Don't be surprised if after adding you need to add more.
    Maybe you could drop into a library and use their computer to do a profile of your pool and equip ??
    Solar Blanket, Well Water, Borax Added. 68
    vol4life's Avatar
    Jul 2015
    Nashville, TN
    29
    I have a gallon of MA. How much should I start with?
    Jan 2012
    7,306
    I get 78 ounces for a 29K plaster pool (via PoolMath) using 31.45% 20 baum MA
    Richard320's Avatar
    Jan 2010
    18,975
    Quote Originally Posted by vol4life View Post
    Half a gallon. And pour slowly in front of the return, so it spreads out instead of settling on the bottom. Probably wouldn't hurt any to make a few psses with the brush to disperse it faster, too.
    Poolmath will do the math for you.
    vol4life's Avatar
    Jul 2015
    Nashville, TN
    29
    MA added and brushed. I wish I could show y'all how green it is. I am taking pics so I will post them when I get to a desktop and build my profile. Just imagine dark green lake water. That would be pretty close.
    I will post new PH in a bit.
    vol4life's Avatar
    Jul 2015
    Nashville, TN
    29
    PH down to 7.5
    Added just a bit more MA. I'll post back numbers after dinner!
    Jul 2012
    Tallahassee, FL
    30,444
    Sweet! Then we will talk about your next step.
    Jul 2012
    Tallahassee, FL
    30,444
    can you also test your fill water now please?
    Kim
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    What device are you using to access this site? I can try out different things and see how you can post pics.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    vol4life's Avatar
    Jul 2015
    Nashville, TN
    29
    PH is down to 7.2-7.3.
    Which test do I do for my fill water? Just PH or the whole thing?
    I am using an android mobile device.
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Everything except cya. There is no cya in fill water.
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
  20. Back To Top    #20
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Okay. On your android device you should have the option to see the desktop site. Try selecting that and then see if you can post a pic.
