Thread: Return Pipe Upgrades ?
    WBChunks's Avatar
    Jul 2015
    UK
    19
    Question Return Pipe Upgrades ?
    Guys,
    I've only had my pool a few weeks and whilst I know I don't have a clue & I'm sure the Intex guys know their stuff, I'm suprised at how close together the pump inlet and outlets are on the pool. I'm also suprised that the return is as high as it is. Is there a particular reason for it?
    I am planning to put a hayward skimmer in next season and having read the thread Homemade Skmmer I wondered if it would be better to not use the standard Inlet/Outlet and build a return that would be lower in the pool.
    Is it worth considering? Have others done anything similar?
    Thanks in advance
    Intex Ultra Frame 24'x12'x52" (8403 gallons). Intex SandFilter SF20220R (10030 liters/hr (2650 gallons/hr)) with glass media , Geobubble Sol Guard 500 Cover, 4x Athena Sun Domes
    Jun 2015
    Stockholm, Sweden
    250
    Re: Return Pipe Upgrades ?
    The idea with return high and close to the outlet is that this creates a circular flow, a vortex that makes the entire body of water circulate. You do this by pointing the return eye away from the outlet and towards the bottom of the pool at a 45 degree angle. I.e. if you are standing outside the pool with the outlet on your right and the return on your left, point the eye left and down to create a clockwise circulation.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    38,319
    I am confused with your terminology of return and outlet. You might mean opposite what we usually say as those terms depend on your point of view.
    Clearer to say suction line and return jet.
    WBChunks's Avatar
    Jul 2015
    UK
    19
    Thanks.
    Still a noob and don't have my terminology down.
    Suction line is from pool to pump and return is pump to pool? Is that correct?
    dakhath's Avatar
    Jul 2015
    Central FL
    35
    Quote Originally Posted by WBChunks View Post
    Thanks.
    That is correct. See you're getting the hang of it.
    A return "returns" the water to the pool and the outlet lets the water "out" of the pool.
    That's how I thought of it when I first started out.
    Watch out though. Hang around here too long and you will contract "sparklypoolitis."
    There is no cure for it. Only thing that seems to help is more cowbell.
    Coleman 5300 gal 16'x48" AGP
    Intex Krystal Clear 2800gph Sand Filter Pump 28647EG (56673EG)
    Intex Krystal Clear Saltwater System ECO 8110
    Taylor K-2006 & K-1766 test kits w/ Speedstir and Samplesizer
    WBChunks's Avatar
    Jul 2015
    UK
    19
