Thread: Heyward Aqua rite salt cell showing chlorinator off low volts?
    Aug 2015
    hainesport / new jersey
    3
    Is the low volts definitely an electrical problem, like replacing a limiter or fuse or could it be the cell needs to be cleaned?
    Re: Heyward Aqua rite salt cell showing chlorinator off low volts?
    What are the diagnostics?
    Support the site
    Aug 2015
    3
    What do diagnostics refer? Is that the information on the diagnostic menu?
    Try this
    Move the switch to off
    scroll through the diagnostics and record (push the button labeled diagnostics)
    wait five minutes
    move the switch to auto
    wait for a click
    go to instant salt
    watch the instant salt until it stabilizes (it should start high and go to the actual instant salt measurement)
    Scroll through the diagnostics and record
    Do the above procedure twice. That will give you four sets of readings. If you post those, we can help some more.
    Also, have the salt tested and report that result.
    Support the site
    Aug 2015
    3
    Since I posted last my board is now reading Chlorinator Off No Cell Power. Thinking I have a board issue now? I put powder shock in the pool tonight as I have already seen signs of algae Any other ideas? I have seen on you tube where some guys have actually sodered a new Limiter on to their board but it looks complicated. Do pool companies actually try to do this first or force you to replace the entire board?
    Is this on an AquaRite or a Hayward automation system such as the ProLogic or Aqua Plus?
    Support the site
