Results 1 to 7 of 7
Thread: How to adjust Electric Valves
    I have a pool with an attached spa that overflows into the pool.
    the pool company set it up so that 75% of the water is returned into the spa creating a nice big over flow.
    The valve that controls this has a Jandy jva 2444 electric valve. Is there a way to adjust this so that the waterfall is not so dramatic?
    14' X 28' igp Free form pool and 6'spa with spill over.
    Aqualink
    2hp Whisperflo pump
    Aqua Rite SWG
    Re: How to adjust Electric Valves
    Any ideas or help would be great.
    Aqualink
    2hp Whisperflo pump
    Aqua Rite SWG
    mas985's Avatar
    Pleasanton, CA
    11,737
    There is a cam inside of the motorized unit that sits on top of the valve. You have to take it apart but you will see that these cams can be easily set for any opening you wish.
    Here is the documentation on how to do it.
    Mark
    Do you think this is something anyone can do. I don't mind trying, but don't want to mess anything up either.
    Aqualink
    2hp Whisperflo pump
    Aqua Rite SWG
    Adjusting the cams isn't difficult, but it can be confusing. Unfortunately, the manual doesn't explain the process very well. You should be able to see where the cams are by reading the manual. By moving the correct cam slightly you can change where the valve stops. As you adjust the cam you need to switch the switch back and forth to see where the automatic rotation stops, and then adjust the cam some more till it stops where you want it to stop.
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    The newer JVA's are a lot simpler that the first ones! Just be careful not to snap off the sensors! Ben there, done that!
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Thanks for the help everyone.
    Should i use my remote control to swtich from pool to spa mode to test.
    If so, do i completely have to put the covers back on before I do this?
    Aqualink
    2hp Whisperflo pump
    Aqua Rite SWG
