Results 1 to 12 of 12
Thread: pressure from Return
    Kell Bell's Avatar
    Aug 2015
    Poughkeepsie
    5
    Question pressure from Return
    Moderator comment - Moved from here. No CYA from the beginning, no FC - Page 2
    I have an above ground pool and having a problem with the pressure coming out of the eyeball. It is good for about 25 minutes then how completely down to nothing. Any ideas on what could be causing this problem
    Live life to the fullest
    38,275
    Re: pressure from Return
    Welcome to TFP!
    What kind of filter? How big?
    Pump size?
    Filter pressure, both clean and when flow stops?
    What does the water look like?
    Kell Bell's Avatar
    Aug 2015
    Poughkeepsie
    5
    I have a Clear water 2 I believe. It is a dome filter. The water is clean
    38,275
    I do not know what a dome filter is.
    Pictures?
    Stump's Avatar
    Jul 2013
    Oklahoma
    143
    Kell, Welcome and please create a signature with details about your pool. Knowing the size of the pool and what kind of equipment you have is a big help to people trying to help you.
    24' Reprieve RD/AG/13K gal Vinyl TFP method
    Waterway Clearwater 175 sqft Cartridge
    Hayward Power-Flo Matrix 1HP Pump 2-Speed
    TF-100 Test Kit SpeedStir Borate Insta Test
    Spreading TFP to All
    Sep 2013
    Connecticut
    728
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Kell Bell's Avatar
    Aug 2015
    Poughkeepsie
    5
    That is my filter and I have grids in my filter
    Cypress, Tx.
    154
    take your return off of the pool and make sure leaves, grass or other matteral isn't blocking the inside of the eyeball or grid. I had a piece of plastic blocking mine, from where it came I haven't a clue.
    Intex 18ft dia. Ultraframe, 6500 gal. above ground Intex pool with Hayward C550 cartridge type filter and Intex Krystal Clear Ozone and saltwater system model ZS8110, Taylor K-2006 test Kit, Pool filter supplemented with Duda Diesel 1 micron filter bag
    Located in Cypress, Tx.
    Kell Bell's Avatar
    Aug 2015
    Poughkeepsie
    5
    Getty Thank you and I have taken the the eyeball piece off and made sure there isn't anything blocking it and I also made sure all hoses are clean going into filter and from the skimmer. I have a DE filter and the help I was getting was telling me you don't have to put earth in it when you clean the grids but I have always been told told you have to. Can someone please tell me yes or no about the earth.
    38,275
    If you have a DE filter, you must use DE. If you have a cartridge filter, then you do not need, and probably should not use any, DE.
    Kell Bell's Avatar
    Aug 2015
    Poughkeepsie
    5
    Thank you
    wjr75's Avatar
    Jun 2013
    IL
    836
    By any chance are you losing prime on your pump? Do you see air on top of the pump basket?
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
