Thread: Raypak heater will not ignite
    kenmacboston's Avatar
    Apr 2012
    Haverhill, MA
    30
    I have had a Raypak 265-280?K BTU about 6 years. 2 years ago, the igniter stopped lighting up the flame. I use a lighter to ignite it and this has worked for the 2 years. Now the ignite will spark (with the code on the unit as SPK), but even with a lighter, the unit does not flame up. I suspect that there is no gas going to the burners. Anyone have similar issues? Could it be the gas regulator (I've turned it off and on many times), or a clogged gas line. Of course, we have company coming over tomorrow! Easy to clean out the gas piping? I installed the unit myself so I can probably do the work myself with someone's suggestions or experience with same.
    Ken Macumber
    18,000 Gunite, salt system, 250K BTU Hayward Heater, Waterfall, Fiber Optic Perimeter Lighting.
    20 yrs pool veteran
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Raypak heater will not ignite
    If you are not smelling and gas, then you could have a bad gas valve. When the unit initially goes to light, it will spark, pilot portion of the gas valve opens, then when the unit senses flame, it sends a signal to open the main portion of the valve to light all the burners. You should be bale to hear/feel when the main valve opens by putting your hand on the valve.
    Now if you are unable to light the pilot at all, then I would suspect that either the gas valve or the pilot assembly has an issue.
    I'm guessing you have natural gas up where you are so you supply of gas should be good. If you have propane, please check the tank to make sure you have propane.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Apr 2012
    Haverhill, MA
    30
    The pilot works, I noticed the igniter will spark (to start the pilot light), and then typically the gas turns on for the burners. No gas to the burners and no smell of gas either. I do notice that the igniter will keep "sparking" after the pilot is lit. I do not understand why Raypak would have a spark igniter AND a pilot.
    Ken Macumber
    20 yrs pool veteran
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    If the unit continues to spark after the pilot is lit, you most likely have a bad system board.
    Paul
    Jun 2012
    western NY
    1,560
    A lot of home furnaces are done the same way. It has to do with how the flame proving circuit works for that style of control board.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
