Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Jandy ain't dandy...
    Aug 2015
    Los Angeles, california
    17
    This thing has been driving me crazy. It's fine... then I go away and my wife tries to heat the spa and.. it's not fine. I am starting to think it's personal. Like CHRISTINE the killer car.
    argh.
    So we have a properly functioning pool system (it seems) in all other ways. Diatomacious earth filter gets semi-annual re-do... and shows 10-20 psi after a top bleed consistently. Pumps work perfectly, automation switches are good and the servos to change pool-spa-pool are good.
    The heater shows LOW PRESSURE sometimes and there doesn't seem to be rhyme nor reason to it.
    It's also home to a bunch of nasty black widow spiders, so I wouldn't mind if the thing just exploded in general.
    But... I should probably just fix it. I've no training in this or hvac etc, but I restore and build custom/vintage motorcycles so I know how to spin a wrench. My gut says it's a wonky pressure switch (where would that be located?) and... anyone have a quick and dirty way to use an ohmmeter to find out if this one is copacetic or not?
    28x14' in ground pool -@15k gallons - max 6' depth. Motorized vinyl pool cover. Jandy LX1 (laars) gas heater. Century/Jandy jhpu2.0-2 pump. Jandy CL580 filter runs 15-20psi usually. there's a secondary 1.0 pump for the water feature that has it's own circuit. We have automated Jandy system.
    Aug 2015
    17
    Re: Jandy ain't dandy...
    i was gonna add more pix but the system won't let me -- ?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Look for something screwed into the plumbing with a grey and a purple wire connecting to it. Well... if this is the manual for your heater: http://www.zodiacpoolsystems.com//~/...ads/h/h0286900
    If you jumper it and the thing works, either the switch is bad or you have low pressure. The 15 psi you have ought to be enough to close the thing. Page 36 of that manual shows what the switch looks like and how to adjust it. Page 53 is an exploded view of things.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by alacrity View Post
    Upload to a service such as Photobucket, then paste the IMG link into the post.
    Aug 2015
    17
    Quote Originally Posted by PAGirl View Post
    Ok i will, thanks!!
    Aug 2015
    17
    thanks Richard! I have the older version - the LX, but it seems most if not all of it is the same. I hope the pressure switch hasn't migrated... Gonna pull it apart tomorrow (before watching MotoGP from Indianapolis!!)
    Aug 2015
    17
    more pics of my overall setup. sorry for the blurriness -- the spiders made me jumpy.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    If you are doing regular maintenance on the filter and keeping it clean, it's probably the pressure switch. Like Richard320 said, you can jump it out and if the heater works, then it's the switch or water flow. Once you verify water isn't the issue, then the switch becomes the suspect.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Aug 2015
    17
    Quote Originally Posted by ps0303 View Post
    Got it - but how would one know if in fact it's the water flow itself? I mean - is there a separate way to test that? It only takes a couple psi to shove the plunger in the switch so it makes contact and opens the circuit, right? So am i right in that pretty much any positive flow should kick it open? I can see LOTS of pressure flowing into the pool-- the pool sweeper flies around like it always has when all pressure is directed that way, and on spa setting, there is a lot of active circulation and flow. There is also none of the telltale air-gapping (sounds of whack/bang) from the heater core or piping that one gets if water flow is low and the pump is sucking/pumping air. What gauge wire do you recommend for the jump? I don't know how many amps are travelling along that line...
    Aug 2015
    17
    this seems like the right schematic... yes? Jandy Laars LX/LT Heater Parts
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Nothing special on the gauge of wire for jumping out the switch.
    I usually test the pressure by placing my hand on one of the pool inlets and if it's strong enough to push my hand away, enough pressure is there. If I can hold my hand over the inlet with little effort, probably not enough water pressure.
    Paul
    Richard320's Avatar
    Jan 2010
    19,074
    My reading of the adjustment procedure on that switch was that it looks for some kind of differential pressure - about 2 psi.
    The pressure switch is preset at the factory for activation
    at 2 psi (14 kPa). Do not adjust the pressure switch if
    the heater is installed more than 15 feet (4.57 m) below
    the pool surface. Consult your local Jandy Pro Series
    representative for recommendations.
    BYPASS
    ADJUSTMENT
    SCREW
    THERMOMETER WITH
    PETE’S PLUGŪ
    Figure 34. Temperature Rise Measurement
    On some installations, the piping from the heater to the
    pool is very short. The back pressure could be too low
    to trigger the pressure switch. If this happens, it may be
    necessary to install a directional fitting or elbows where
    the return line enters the pool. This will increase back
    pressure enough for the heater to operate properly.
    Aug 2015
    17
    There is PLENTY of pressure by this test. thanks.
    Richard: I saw that in the service manual you posted...
    I also found what appears to be the right manual for this particular (older) LX heater here
    https://www.google.com/url?sa=t&rct=...99804247,d.cGU
    What I would love to find (but haven't yet) is a couple pix or a video showing the easy way to remove the panels to get to the pressure switch. I have the lower front cover off -as you see in the pix. Given the spiders etc (I know I sound like a weenie - but these black widows are not to be trifled with)... I don't wanna be reaching up inside under the top front cover. Does the whole top come off?
    Richard320's Avatar
    Jan 2010
    19,074
    Haven't got a clue.
    38,539
    What do you mean the filter pressure is 10-20psi? That is a huge range. We recommend backwashing when the pressure rises 20-25% or the flow drops too much. If you have a clean pressure of 10 psi, then there will be virtually no flow by 20psi.
    Qwaxalot's Avatar
    Jun 2012
    439
    Pressure switch is behind the upper front panel (#59 in the parts breakdown). It's secured by screws running vertically from the bottom of the panel. Remove the screws and the panel slides down.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Qwaxalot's Avatar
    Jun 2012
    439
    One more comment. This unit displays the pressure switch error when (in remote operation) there is no call for heat. That is, the Aqualink thinks it's set temperature has been reached (a more complete explanation is in the Jandy manual).
    Aug 2015
    Plano, TX
    217
    Just to cover the obvious things...Are you sure the "low pressure" is in reference to the water and not the gas?
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Pool heaters have no way of knowing about gas or pressure.
    Paul
  20. Back To Top    #20
    Aug 2015
    Plano, TX
    217
    You see in the pic the sticker that says '3.0" WC'? That refers to the minimum gas pressure required going into the unit while the inlet valve is open. That refers to 3 inches of water column which is a measurement of pressure. Three inches of water column is equivalent to 0.108 PSI. The regulator coming off the gas meter that supplies your house should be a 0.25 PSI regulator which is the standard for all residential appliances that use natural gas. This being said, you should have 0.25psi before inlet valve with valve closed. When valve opens, you should have at absolute minimum 0.108psi. Anything less than that, your heater will shut down due to low gas pressure. Just a note about something related, if your flame is burning on low pressure, it will create more soot than usual which will build up on your flame sensor causing it to fail prematurely.
