Results 1 to 9 of 9
Thread: Can you test bleach for chemical effectiveness
    Aug 2015
    Grandy, NC
    135
    This may sound strange, but discussions on bleach storage and product becoming less useful, is there a test that could be performed to see if product still good or less and would need to use more for good results.
    Karen
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    38,521
    Re: Can you test bleach for chemical effectiveness
    There are methods to attempt to test the strength, but they can be difficult to dilute accurately enough to get useful results. Try the search function
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Hi karen, if you know your volume accurately and since you have a good test kit, you can add a known amount of chlorine, then use poolmath to see what increase in chlorine to expect for the expected strength of chlorine. Measure before adding and 1/2 hour after and see if you got the expected result. If not the strength is lower than you thought.
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Aug 2015
    Grandy, NC
    135
    Thanks. I bought a bunch of chlorine for my SLAM and it doesn't look like I'll be needing it all. Will continue to use chlorine for the pool but season coming to close, bleach will be stored for a while.
    Karen
    May 2014
    277
    For best storage, keep your leftovers cool and out of the sun, e.g. In the basement
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    In this post, I describe a very accurate dilution method that will enable you to easily test chlorine strength.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    38,521
    Quote Originally Posted by epro05 View Post
    If you have a scale and syringe laying around ....
    JoyfulNoise's Avatar
    May 2015
    13,254
    You could always purchase a Taylor Bleach Test Kit. The K-1579 retails for about $60. For those that use a lot of bleach in a Stenner Pump or Liquidator, it might be a useful tool to assess bleach strength.
    Matt
    Aug 2015
    Grandy, NC
    135
    Thanks to all for help!
    Karen
