Thread: Water level
    Water level
    Hello!
    Have my hot tub all hooked up and chemicals are balanced well (just finishing up the dichlor part of the process and almost ready for bleach). Anyway, I have a question about the water level. Where it is now, it covers the very top jets halfway. When I look at the two filters, they are both "telescoped" to full extension and they are just slightly uncovered so they are more at water level or very slightly above. Where should my water level be? My assumption is above the filters, but I am asking because when I have it that high, just one person getting into the hot tub overflows it by the time you turn the jets on. And it truly overflows a lot. I can't imagine the overflow when 2 or more hop in. I'm not sure if this is bad design or my water level where it currently sits is ok??
    Thank you!
    13,000 gallon plaster salt water pool. Jandy DEV60 filter, Jandy AquaPure SWG (APURE1400)
    Oct 2014
    Central PA
    87
    Re: Water level
    I keep my water level just below the neck jets, there is a small shelf below the neck jets and I try to keep it there, I keep the neck jets off unless I am using them and with two people in the tub it displaces just enough water to submerge the neck jets.
    Re: Water level
    Thank you! That makes me feel better. I'll be doing the same.
