Hi, just getting started on this site, have been reading and learning a lot. I am having a slight staining problem that I believe is organic, it clears up after shocking but starts to return as my chlorine level returns to normal. Water clarity is fine, this is the only issue I continue to have. Was using trichlor but will be switching over to liquid chlorine. Was also using cal-hypo to shock and will be stopping that soon as well. Just got my test kit today and obtained the following results from my initial test.
FC - 13
CC - 0.5
TC - 13.5
PH - 7.6
CH - 325
TA - 180
CYA - 90
15,000 gallon/plaster
Trying to locate ideal ranges as well as what FC level should be maintained at my CYA level as well as how to calculate the appropriate amount of chlorine needed for shock purposes. Thought I saw this information on the site earlier but can't locate now.
Thanks for any help you can provide.
FC - 13
CC - 0.5
TC - 13.5
PH - 7.6
CH - 325
TA - 180
CYA - 90
