Thread: 1st Time User - 1st Readings
    Aug 2015
    Village of Lakewood, IL
    5
    Hi, just getting started on this site, have been reading and learning a lot. I am having a slight staining problem that I believe is organic, it clears up after shocking but starts to return as my chlorine level returns to normal. Water clarity is fine, this is the only issue I continue to have. Was using trichlor but will be switching over to liquid chlorine. Was also using cal-hypo to shock and will be stopping that soon as well. Just got my test kit today and obtained the following results from my initial test.
    FC - 13
    CC - 0.5
    TC - 13.5
    PH - 7.6
    CH - 325
    TA - 180
    CYA - 90
    15,000 gallon/plaster
    Trying to locate ideal ranges as well as what FC level should be maintained at my CYA level as well as how to calculate the appropriate amount of chlorine needed for shock purposes. Thought I saw this information on the site earlier but can't locate now.
    Thanks for any help you can provide.
    JohnKash
    15,000 gallon plaster
    Sta-Rite Cartridge Filter
    Sta-Rite Max-E-Therm Heater
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: 1st Time User - 1st Readings
    Welcome to TFP!
    Those are some nice numbers. CYA is a little high which will require higher chlorine levels but it is manageable.
    Chlorine level is set based on the Chlorine CYA Chart. Keep it at target and don't let it drop below minimum ever to keep the pool sanitized and algae free. Shock level is also listed. It is safe to swim with FC between minimum and shock level.
    Here is what you are looking for on Pool School - Recommended Levels
    And another great page to read here, Pool School - ABCs of Pool Water Chemistry
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Welcome to TFP are you using one of the recommended test kits. TF100 or taylor K-2006
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Welcome to TFP!
    I'd like to hear more about the stains that come and go. Color, shape, feeling to the touch?
    Support the site
    Aug 2015
    5
    Thanks, just what I was looking for.
    Yes, the TF100.
    Color hard to tell really, definitely not green, more of a grey to start out then slowly get darker. Kind of wavy in shape. Hard to get a feel as plaster/pebble base. Until I found this site was always trying to get my chlorine levels down to 1-3 range after shocking which is more than likely the problem. I now see I have to maintain higher chlorine levels based on my CYA.
    JohnKash
