Thread: Hayward S180T fittings leak.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    A week ago something happened.
    I had the water level steady declining bery little over the summer since beg. of July until the last weekend. I had semi rigid Tiger striping pipes (almost impossible to clamp well) connecting my pump to the filter inlet and the return to the pool. I think my real estate agent decided to put my vacuum hose near the pump, moved it....and everything started leaking.
    I cheked around the pool, all is fine, skimmer not leaking either.
    But the filter hose adapter fittings leak.
    I put three or four layers of theflon tape, still leak. In a day I lose about 1/3" of water. Only when equipment runs, nothing overnight when it does not run.
    So....how do I stop the leak? Would those fittings with flanges and gaskets help?
    Neec to solve fast - we go on vacation in a week and the pool will lose enough water in a week for the pump to run dry.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Re: Hayward S180T fittings leak.
    pmub?
