Thread: Backfilling/Landscaping HELP!!!
    Aug 2015
    Pittsburgh
    3
    Hello All!
    First time pool owner and I am clueless.
    We had a 24 ft round Quantam Resin Pool installed about a week or so ago by Pool City.
    Our yard is sloped so we had to have 36" excavated from one side down to the level portion where we have the pump and steps.
    they told us that once the pool was filled that we should cover the bottom rails with 6 in of dirt at a 45 degree angle.
    I would like to put approx. 18" of river rock around the base of the pool to create a barrier between the grass and the pool so we don't have a weed issue and don't have to mow close to the pool. I also figured this would give it a clean look and cut down on erosion of the sand etc since our yard is sloped.
    I have looked at a few dozen forums and pics etc. and no one has mentioned putting dirt back around the pool.
    What should I do?
    If I put the 6 in of dirt then cover with landscape fabric or weed blocker and then cover with river rock will it be too high?
    Can I skip backfilling the dirt and just use rock?? either way I think I will need an edger around the perimeter of the rock bed to keep them contained
    Please help.
    Britt
    Quantum Above Ground 24' round 54' high
    2hp pump Vision Nature2 mineral filter
    Apr 2013
    Sacramento, CA
    2,769
    Re: Backfilling/Landscaping HELP!!!
    Welcome to TFP!
    I wouldn't put dirt I would use a smooth river rock. About 6 inches.
    Read up on pool school
    Follow the basic concepts taught on here and pool ownership is easy!
    Have fun and post some pictures!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Ask them WHY they need a 6 inch berm of beveled dirt.
    Aug 2015
    Pittsburgh
    3
    They said it's to keep the sand from washing out from under the liner and to lay a solid foundation for the rock
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Very valid reasons. You do NOT want to take any chances of that happening.
    How about you do this for us? Take a few pics. Use photobucket or such and share them with us so we can see what you have. I am sure someone here will have some neat ideas.
    Kim
    Apr 2013
    Sacramento, CA
    2,769
    No dirt. Smooth small river rock.
