Results 1 to 9 of 9
Thread: Constantly recalibrating a swimpure
    I have a T-Cell 15 that is around 4 years old. I am running into a problem where the salt level is not registering properly. My salt is at 3200 but it keeps showing much lower than that to where the salt generator turns off.
    If I recalibrate back to 3200, it seems to generate chlorine for a day or two, then the the salt reading goes back down to where the salt generation turns off.
    I have cleaned the unit but it doesn't seem to make a difference.
    My question is, does this mean the unit is going bad or the controller or a censor????
    Thanks
    17K gal, IG outdoor uncaged crystalcrete (yr 2002), 1 1/2 HP pump, Hayward 1750C cartridge filter, Hayward SwimPure SWG, No autocleaning --- Southwest Florida
    22,548
    Re: Constantly recalibrating a swimpure
    Continually reading low salt is an indication of a failing cell. Since it's four years old, it's near the end of its life anyway. Your probably going to need to replace it very soon.
    38,275
    You can not actually re-calibrate a Hayward SWG.
    I agree that you likely need a new SWG cell. You could have your existing one tested at a pool store.
    Jun 2011
    Long Beach, CA
    2,784
    The pool store is a pass or fail type of test and if the cell is on its last legs it might pass the test but it could still need to be replaced. I think that over 90% of the time a SWG has those symptoms the cell needs to be replaced.
    Thanks for the responses.
    If it is most likely the cell then, I may just recalibrate it every two days until the thing produces no more chlorine. Maybe I can get some more use out of it.
    Can you post the diagnostics?
    Support the site
    38,275
    One trick that might help, although not sure if this has been tested out if it works. If you can change the controller and tell it you have a smaller T-cell, it seems that it would start to think the salt level is higher and might sort of work for a little longer.
    Disclaimer, I am not sure if this would cause any problem with the controller.
    I discovered this when my SWG was reading very high slat levels and found that the cell size was too small.
    What is involved in running diagnostics on the T-cell?
    Try this
    Move the switch to off
    scroll through the diagnostics and record (push the button labeled diagnostics)
    wait five minutes
    move the switch to auto
    wait for a click
    go to instant salt
    watch the instant salt until it stabilizes (it should start high and go to the actual instant salt measurement)
    Scroll through the diagnostics and record
    Do the above procedure twice. That will give you four sets of readings. If you post those, we can help some more.
    Support the site
