Thread: Can high CYA levels cause tile chipping issue?
    Apr 2013
    Phoenix AZ
    3
    I have an issue where my tiles are chipping above the water line. I use chlorine pucks 1-5ppm and keep the ph level within range 7.5-8.0. The CYA level has been between 80-130ppm.
    The pool was drained last Nov 2014 after 2 season as the tiles started to chip in areas and replaced. Now not even a year later the same issue is occurring.
    The pool store has never heard of anything like this and Noble Tile has never encountered such a thing, I'm wondering if it has anything to do with the type of chlorine pucks I'm using or if the CYA level is causing the problem?
    Any help or ideas?
    10,000 gallon in ground
    Noble Tile mini pebble Midnight Blue with glass beads
    Rainforest RF38 tile
    PoolVergnuegen 2x Suction PoolCleaner, Hayward sand filter
    Phoenix AZ
    Jul 2011
    Arizona & California
    805
    Re: Can high CYA levels cause tile chipping issue?
    No, high CYA would not cause that to happen.
    Probably defective tile and high heat in combination.
    Sep 2013
    Connecticut
    728
    As a note to the original poster, onBalance is the person we all hope will look in on threads about plaster and tile issues here on the forum - he is an expert. I just wanted you to realize that you have received an educated response to your question, and weight it accordingly.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Aug 2014
    Shallotte, NC
    693
    In issues unrelated to pools, I have seen this happen, but it take two conditions 1) improperly fired tiles allowing them to become water soaked and 2) temperatures below freezing. Were this due to conditions relating simply to water, the bottom of the tile would be spalling, not the top!
    Aug 2015
    2
    Do you brush the pool? I'm just wondering if maybe the chipping is happening from a brush hitting it or something?
    Apr 2013
    Phoenix AZ
    3
    Hi ya'll, the temps do not get below 28 degrees in Phoenix and freezing should not be an issue. I did call out the tile company and they think the tile batch may be defective. I'll know once they come out and take a look at all the tiles. I use a soft pad to clean the tiles and try not to hit the tiles when brushing.
    I will let you guys know what tile/pool contractor says when I find out. Appreciate the help
    Phoenix AZ
