Thread: Wiring help needed. Dual mechanical intermatics to single electronic- dual wires?
    May 2013
    Fort Lauderdale, FL
    423
    Help! I went to install my new intermatic electronic timer and I'm confused. I have dual mechanical timers. One for the pump, one for the boost pump (polaris). I also have a heater and salt water generator on the main pump timer.
    The issue is that my 240v breakers have wires coming off each side of the breaker. So 110v a side. The mechanical timers have two inputs and outputs, one for each 110v wire. Well the electronic timer only has one input/load terminal for each of the 3 circuits.
    I have 240 breakers for my main pump, boost pump, and the heater. How do I wire all of this up?
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    38,524
    Re: Wiring help needed. Dual mechanical intermatics to single electronic- dual wires
    Looks like the new timer will only switch one leg of the 240V supply, which is exactly what the drawing shows.
    So one leg coming off each breaker goes directly to the pump/heater and the other is run through the Line/Load terminals.
    May 2013
    Fort Lauderdale, FL
    423
    Thanks, I was afraid of that. I'm sending that sucker back to Amazon. I don't want hot power always going to my pumps.
