Thread: Cant't close the belt on my Jandy cartridge filter.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Washed it, put all back, put the top back, then put the belt (clasp?) on. The distance between the ends is about 1/3" larger than I need for the bokt to reach the nut. No obstructions, checked that, sprayed the belt inside with water just in case. Also sprayed the seam. No luck. I need some vice possibly to pull it together but usually this is not the case so I need it, right?
    What am I doing wrong or how can I succeed in closing it?
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Re: Cant't close the belt on my Jandy cartridge filter.
    OK, figured this one by myself.
    I have a vice.
    Put it agains the gap, tightened enough so when released it stayed close enough to catch a thread.
    The single problem was, this is a 40 pound vice, holding it in hands while clamping is, how would I say it...inconvenient but it worked.
