Results 1 to 7 of 7
Thread: Algae all gone, now what
    Sharkygirl's Avatar
    Oct 2014
    Key West, FL
    25
    I will try to keep this brief- if that's possible. My pool is at my vacation home. So I'm not there. I have SWG's for the pool and spa. I hired a pool person to manage my pool. They came once a week. Well they didn't watch the salt levels in the pool, I had a leak in the auto-fill line and the parameters set for the SWG didn't match the salt levels in the pool and the board for the SWG burned out. Well, this is what I'm told anyway. My pool turned green in less than 6 days. The pool guy was putting chlorine tabs with cya in the pool and sent my cya 150+. In the end, I told the pool guy he is done and hired a new pool company. They got the pool "sparkling" in 2 days. They also used an algaecide. So my question now is, once the SWG is up and running - is it necessary for them to keep adding this algaecide for "maintenance"? It is called "Yellow Treat" by United Chemical. I can't wait to get back to my home for the winter. It is so difficult to leave the pool maintenance to someone else.
    New Build Oct. 2014 : SWG Infinity Edge Pool, 10,000 gal, IG plaster, and IG Spa 600 gal, year round FL pool, 2 Jandy ProFlo pumps, 2 Pro Series Heat Pumps, 2 Aquapure salt system, 2 Jandy Levolor autofill.
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    Re: Algae all gone, now what
    See if you can get them to buy into this system? It never hurts to ask? I can see them charging you more for frequent stops but maybe they could keep the pool in the condition you want?
    17K Gallon,IG Vinyl,1hp Pentair Challenger,Pentair TA60 Sand Filter, Hayward Colorlogic,Re-lined 06-20-15, TF-100,SpeedStir,Lagunitas and Margaritas. Zappafan Pool Build
    Jun 2014
    15,261
    We don't typically recommend the use of algaecides either because they don't work, are not the root cause of the issue, or add metals to the water (i.e. copper in your case). Proper (consistent) management of FC (chlorine) and CYA (stabilizer) is what's needed to keep that water clear. Not sure about that product specifically, but if it does contain copper, you could end-up with metal staining issues later or even green hair if the other chemical levels get out of whack. So keep a watchful eye on that as well.
    I suppose others will have a comment or two and this thread continues. Have a nice day!
    Sharkygirl's Avatar
    Oct 2014
    Key West, FL
    25
    Thank you. I do not think this product contains any metals. It is 88% Bromide. Yellow Treat | United Chemical Corp I like this forum because it clears up confusion and is an excellent resource. My goal is to have a trouble free pool. Personally I want the least amount of chemicals added to the water I swim in period. It's a difficult situation for me because I am not always there. So for me to take care of my pool on my own for 6 months and then have someone else do it for the other 6 months is impractical. I like the idea of getting my pool company on board with this trouble free method. Once I'm there I will talk to them about it. I'm just very grateful they were willing to come on board and rescue me. So if I'm understanding correctly, it shouldn't be necessary to add any algaecide after we are certain all the algae has been killed off - providing the chlorine levels are adequately maintained. By the way they did not drain the pool- they put in a chemical to bring the CYA down. It's still too high at 100.
    30,432
    To our knowledge, there is no chemistry available to reduce CYA. Are they telling you that? What chemical did they use?
    Sharkygirl's Avatar
    Oct 2014
    Key West, FL
    25
    Sorry for the delayed reply. I will ask them and let you know.
    Sharkygirl's Avatar
    Oct 2014
    Key West, FL
    25
    Apparently they did not add anything to reduce the CYA. However, they did find a leak and fixed it. My Cyanuric acid levels are low now. It is a bit of a puzzle. My chlorinator sensors were all replaced 2 months ago and now they are not working again. I will keep updating. What I do know is so far it has been an education to say the least!
