Results 1 to 17 of 17
Thread: no pump one day is Ok?
    Jul 2012
    Whidbey Island, WA
    397
    good morning
    would like to get kWh consumption without the pool pump running
    and now have a meter that reports kWh every day
    ok to turn the pump off for a day? or something bad will happen?
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: no pump one day is Ok?
    Raise the FC beforehand. Make a lap around the pool with the brush while the pump is off just to mix things. Shouldn't be a problem.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    .......or just get in and stir it up after mixing a bit!
    mas985's Avatar
    Pleasanton, CA
    11,737
    You could also take a meter measurement with the pump on vs off and then subtract out the energy use during it's run time.
    Mark
    Jul 2012
    Whidbey Island, WA
    397
    got it, thanks, will do
    tho I hate brushing; never see anything happen; so is unfulfilling
    I like to vacuum; lots of instant gratification
    but
    will do, thanks
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by mas985 View Post
    wish i could do that but...
    the output on the meter is 80kW units so does not change till 80kW units consumed, several days
    however
    now have an antenna that sends daily use to Puget Sound Energy and I can get daily reads on their web
    why do I have 80 kWu meter? something to do with how Puget Sound Energy brought power to this place which I don't understand
    Jun 2015
    Santa Fe Springs, California
    13
    If you can retrieve daily usage on their website, can you also get an hourly breakdown? I know my electric provider (SoCal Edison) provides that info. Takes a bit of clicking around to get it, but it's useful in your situation. Being that you have a "smart meter" perhaps your utility provides hourly as well.
    18,500K IG plaster, Pentair FNS+60 DE filter, Pentair Intelliflo VF 3HP, no SWG, Taylor K-2006-C, in Southern California (harsh water restrictions)
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by Donniesmail3353 View Post
    that would be slick
    will check it out
    even if I had to call in, would be slick
    mas985's Avatar
    Pleasanton, CA
    11,737
    We get hourly usage from the PG&E web site as well as the meter displays instantaneous power which is why I had suggested that. I think most of those digital meters can be configured to display instantaneous power but for some reason some power companies choose not to show it. You might ask if it can be enabled for your meter.
    Mark
    Jul 2012
    Whidbey Island, WA
    397
    thank you
    will check that out as well
    Jul 2012
    Whidbey Island, WA
    397
    well, PSE answered
    no hourly reads
    no meter change
    so that is that
    but...
    tomorrow should have daily read with no pump so will have in fact an answer to house kWh with no pump
    Jul 2012
    Whidbey Island, WA
    397
    It worked!
    No pump one day and all is fine in the pool
    By kWh subtraction pump consumes about 20 kWh / day running 12 hours / day
    And amps(7.4) * 240 / 1000 * 12 = ~21 kWh
    So all agrees.
    Nice when things agree.
    Jul 2012
    Whidbey Island, WA
    397
    so had an unrequested one day no pump test
    had an unusual Aug wind storm with trees down all over Whidbey and power out 29 hrs
    pool filled with fir tree needles/cones and cooled down but was otherwise Ok
    confirmed one day no pump > no problem
    I did sprinkle couple of gallons round the perimeter as per Richard320
    used pool water to flush as well pump was off
    (kids said "this is really really exciting")
    I kinda agreed
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Good idea on the use of the pool water!! I honestly think I would not have thought of that!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by pabeader View Post
    There is a down side. Bacteria in the septic system eat up the poop and chlorine kills them. But they should recover from a little bleach. And when the big one (earthquake) hits WA State, they will get lots and lots of bleach so was good rehearsal for them.
    And
    while the buckets stood in the bathroom lots of chlorine disappeared. FC on the water after standing was 2 so the dose to the septic system was kinda low.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Heck, we have more FC in my city water than in my pool. I swear!
    mas985's Avatar
    Pleasanton, CA
    11,737
    More than likely it is CC and not FC. Municipal water districts tend to use CC as a disinfectant because it lasts longer in the water distribution system. Unfortunately, it tends to use up FC when added to pool water.
    Mark
