Thread: Fresh gunite leaching milky white substance.
    Feb 2015
    Dallas, TX
    36
    Greetings,
    After a long wait, our builder finally poured gunite this week in North Texas. We have been watering multiple times a day in the heat. ( sometimes 6 -7 times.) In the mornings, one part of the pool ( where were having water before the pool went in ) in a corner near our steps will still be slightly damp, but is leaching some milky whitish substance. Any thing to be concerned about? We are doing mini pebbles, I assume that it won't leach through them?
    Thanks.
    In Ground 17X29 90 ft perimeter; 3.5 to 5 depth; 15,000 gallons, Stonescapes Tropics Blue, Jandy stealth 1.5 HP 2 speed, Jandy 450 SQ cartridge, Jandy JXi 400K BTU NG, POLARIS 280 W/ HP booster pump, North Texas
    Feb 2015
    Dallas, TX
    36
    Re: Fresh gunite leaching milky white substance.
    Attachment 41393[QUOTE=TriPool;899204]
    Adding a picture from noon today. If I don't wash it away it will eventually flow down to the deep end of the pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I've seen similar stuff on plain concrete, but I wasn't sure until I emailed onBalance, a member here. Here's his reply to me (I was hoping he'd respond directly...)
    ...go ahead and him that it is normal for gunite to leach white "stuff." Gunite is very porous and often does that. The white stuff is actually common calcium carbonate. It won't be a problem once they plaster the pool.
    Feb 2015
    Dallas, TX
    36
    Awesome thanks! It has been quite the ordeal to get to this point due to water/wet soil. So this is very helpful.
