Results 1 to 13 of 13
Thread: Backwash
    rdshackleford's Avatar
    Jul 2015
    Coatesville, PA
    116
    Backwash
    My water is crystal clear and when I backwash after a week (no pressure rise), the backwash water is very green, like pea soup color, for a minute. I only backwash because I know the gunk is sitting in the filter and I feel I should get it outta there. Is this wrong? Am I just wasting water?
    St. Louis
    12
    Re: Backwash - how often?
    Prior to my pool resurfacing late last summer I had to backwash once per week. The plaster was old and had been painted and the paint was coming off when I brushed or ran my dolphin. With new plaster I've only backwash once this summer since the pool cleared up after the slam I had to do after opening.
    25k gallon, IG gunite, Plaster/Pebblesheen (new in August of 2014), Sta-Rite 300lbs sand filter, TF100 Kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Back washing is generally recommended when you have a 20-25% pressure rise. Sand filters actually work,better a little dirty as it helps catch smaller particles.
    Now,what worries me is your green pea soup description. It sounds to me that you have a low level algae bloom going on. The filter is catching it (not all) and it is growing in the filter until you backwash.
    You need to,conduct an OCLT to see if something is growing in the water you can't see yet.
    Support the site
    Jul 2015
    Coatesville, PA
    116
    Re: Backwash
    I did have a visible algae bloom situation in the pool up until last week when I learned what my proper chem levels should be from TFP. I read a bunch, got the FAS-DPD kit, and things are improving rapidly.
    I changed the filter sand last weekend and backwashed the new sand before running the filter. Today I did a backwash, got a minute or 2 of greenish/tanish backwash water, and the PSI lowered less than 1/2psi (from 13psi which on my very old gauge may not be numerically accurate.) It was not quite the pea soup darkness as the previous weekend, and the backwash took less time to clear. The brown dust-like substance collects on the bottom in a few days, mainly on the liner seams and in the corners. The Nautilus Plus robot gets everything spotless and its filters come out very green like a pond.
    I did the OCLT test last night and lost only 0.2 FC between 8:30pm and 6:30am.
    Water is crystal clear and my chems this morning are: FC 5.8, CC 0.2, pH 7.7, TA 90, CH 250, CYA 60
    -R
    p.s. thanks to the moderators for splitting my post into its own thread
    29,085.1 gal inground grecian vinyl, Hayward Super Pump VS, Hayward S-240 sand filter, Dolphin Nautilus Plus (aka Agador Spartacus), Taylor K-2006 kit, nice pool brush, crappy leaf net, frogs
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Re: Backwash
    While the dust on the bottom can be pollen settling, the fact that the filters are green and you had (or have) an algae bloom, if you didn't SLAM your pool, just getting your levels right won't eliminate it.
    I believe you need to SLAM and get rid of the algae and then let numbers get back to normal. Then that should eliminate the green soup in the sand filter and your nautilus filters.
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,643
    Re: Backwash
    R, I would think of running your FC levels at SLAM level for the next couple of days just to see if your water can get any clearer.
    Kim (shhhhh but also I do a short backwash after running my vacuum because I do not like the thought of the dirt just sitting in my filter)
    lefty51's Avatar
    May 2015
    451
    Re: Backwash
    Quote Originally Posted by kimkats View Post
    Kim (shhhhh buy also I do a short backwash after running my vacuum because I do not like the thought of the dirt just sitting in my filter)
    Ohhhh.... I'm telling !
    May 2014
    Franklin, NC
    9,197
    Re: Backwash
    Quote Originally Posted by lefty51 View Post
    we already saw it, it's going in her records.
    Support the site
    Jul 2012
    Tallahassee, FL
    30,643
    Re: Backwash
    Oh believe me I tried BUT all I could think of was the dirt that was on the bottom just sitting in my filer. It HAD to GO! LOL
    Kim
    Jul 2015
    Coatesville, PA
    116
    Re: Backwash
    I'm a little confused. Wouldn't running the OCLT show if there was algae in the water? And my water is crystal clear and the OCLT drop was only 0.2ppm.
    The brown/tan dust seems to be happening less and less every day now. If you look close at the photos, you can see a little bit of this sediment collecting on the liner seams, about 24 hrs since the last cleaning (which is much less than what was accumulating last week).
    May 2014
    Franklin, NC
    9,197
    Re: Backwash
    Well with a .2 OCLT loss, crystal clear water and no CC it is safe to assume what you are seeing is blowing into the pool, not growing there.
    A little late in the season for pollen, but I know my neighbors sunflowers have a yellow powder coming off them now. Anything around the yard that may be casting off a dust/powder?
    Support the site
    Jul 2015
    Coatesville, PA
    116
    Re: Backwash
    Certainly its a big open area and whatever floats by can cause some sediment. I have not noticed pollen on the furniture for a long time now. It was a light brown or tan color, but when disturbed it would take on a more greenish hue as it dispersed into the water and disappeared. Too fine of a dust to be felt when I tried to touch it. Too bad I just sold my microscope on ebay, or I would try to capture a sample. I know a lot of chemists, maybe one of them knows a microbiologist that can take a look. But the dust seems to be lessening over time. Maybe it was remnants of an algae bloom on its way out? Before last weekend, my sand was very old and probably not enough of it. And since I changed to the stronger variable speed pump this year, maybe it was forming channels down to the laterals. When I took the S-240 clamshell top off, I found the sand on one side of the filter had a conical depression, sort of like a sinkhole.
    Back to my original question, is it better to wait for a pressure rise in the filter before backwashing, or backwash more often as long as the backwash water is greenish?
    -R
    May 2014
    Franklin, NC
    9,197
    Re: Backwash
    I always wait for the pressure to rise, unless I'm adding a little cellulose fiber (DE replacement) to the sand. A slightly dirty sand filter gets smaller particles out of the water.
    Support the site
